Anyone ridden the R and X?
So I used to own a 2006 CRF250R back in highschool but we moved and I had to sell it for college. Fast forward to today and I am currently in the Marines just got stationed here in Kaneohe, Hawaii. I am looking into getting another bike and I know there is a track around here as well as quite a few good trails. I really need the X because I have to street legal it so I can drive to and from the track as well as get around to the trails with it. Basically I am curious as to how the X stacks up against the R. Is the detuned motor a huge difference as well as the suspension for track use? Just hoping I will not be let down after riding the R for a couple years. Also considered a 450X but not sure I need that much bike as I had a great time on my 250R when I had it. Thanks guys.
R more betta for track
X better for trail.
It's a tough call if u want to do both, I have a 06 CRF 250X & 07 CRF 450R I will ride the 450 any day of the week over the 250X even on the trails. Not the best comparison becouse one is a 250 and one is a 450. The bike manufactures do a really good job designing the bike for a spacifc use. My advise is ask ur self what do u really want to do more and that will help u answer the question. I will say this my x is defiantly not great for track. If u really get back into riding on the track u will wish u had the R IF u get the X.
Hope this helps
I just recently got to try my buddies 06 250r at the track after riding my 07 250x for so long. I have my x uncorked a lil bit with some CCC mods but no aftermarket parts. Even with some mods, his stock 06 was a world of difference in power, snappiness, and weight. I would definently get the r if I had the chance now, no question, even for trails. The x was a great learner bike for me (started out riding desert) but riding the r has changed me, and since u started on an r, you would feel restricted on the x no doubt.
I am thinking of going with a 450x to find sort of a mid ground. Granted it's a 450 but it will give me my X capabilities and extra power that I would be missing going from a 250r to a 250x. Only thing is the extra weight but no bike is perfect. If I had a truck (currently have a little mitsubishi sedan) I would just grab a 250r and truck it over to the riding areas, but unfortunately I need something that can drive itself there.
I had a 2006 R with all kinds of mods, exhaust, suspension, etc. I got rid of it about a month ago to get a 2006 X. My X is bone stock besides a Baja Designs street legal kit and aluminum engine guards, a glide plate, and a couple other aluminum guards and it only has about 30 hours on it. I unfortunately haven't gotten the chance to see dirt on my X yet, but just from riding around the block on the street I can definetly feel a difference. The X is noticeably heavier, but I'd say a better beginner/trail bike than my R was. If you want to go out and compete at the track than the R is the obvious answer, but I think the X can be competitive on the trails and in the desert with a little bit of modding. Hope it helps.
P.S. thank you for serving our country.
I have ridden the following
Stock 05 CRF250R
Stock 04 CRF250X
Stock 07 CRF250X
Heavily Modded 07 CRF250X
Modded 08 CRF250R
That being said I can say that the stock suspension on the X models is good ONLY for trail riding. I am about 30 pounds under weight for the 250x and even with that the suspension can't really handle much of a hit. The front forks also seem to blow through the compression dampening very quickly making it unpredictable at times especially in sand. The 250R's that I rode seemed MUCH snappier than the stock X model bikes however my 07 X with all the mods I have done over the years is just about as snappy as a 250R now. The suspension on the 250R's that I have ridden were great on the track as you would expect. It would soak up anything that I could dish out at my skill level. Take the same bike and take it in the woods and it's like riding a pogo stick. Suspension just bounces off of everything. As far as the transmissions go I think after riding both that I actually prefer the close ratio tranny of the R. The spacing between gears on the X is just slightly too much. As a result I usually run a gear lower on my X and rev the piss out of her to keep that power coming.
If the question is which bike is a better a stock 250R or a stock 250X I would pick the 250R every time. Given an unlimited budget and again asked the same question I would take the X every time. Just as a frame of reference I have done the following to my 07 250X (performance and handling wise)
-Suspension revalve for woods
-MRD Racing Exhaust
-07 250R Cylinder Head
-07 250R Cam
-13.5:1 piston
-JD Jet Kit
-Cut open airbox
-Removed backfire screen
-Pink wire mod
-R&D Flex jet fuel screw
-Scotts Sub mount damper (untested)
-22mm offset triple clamps (untested)
With all these mods my X is now on par with the R's that I have ridden. Add in the fact that you also have a light, kickstand, and estart and the X is a winner in my book. Looking back at the thousands of dollars I have dumped into this bike to get it to perform and handle like I want I probably should have just ponied up the extra cash and bought a KTM. That being said I do love my 250X and will likely keep it forever since it was the first new bike I have ever purchased. Hope this helps.
  • Similar Content
    • By Connor Wright
      Hey I have a crf250x 2005 I was riding today in top gear flat out and when I slowed down blue smoke just poured out the exsaughst then I happened to open the air box lid and saw it has what looked like engine oil in it then took out air filter and noticed that there was splatters of engine oil on the inside and that and the channel that goes to the carby had engine oil all over it.
      Also bike got a top end rebuild 15 hours ago
      The engine still runs good and sounds normal
      why would this be happening on a resonabley fresh engine
    • By mikemcbride
      Hey everybody. Quick question for y'all. I recently went riding and about halfway through my ride my motor seized on my '07 CRF250X. I haven't investigated it much but I checked the oil when I got home and there basically was none so I'm assuming that was the culprit. There weren't any metal shavings in the filter or on the plug either. At this point I'm trying to decide to rebuild the motor or just sell the bike as is and let the next buyer deal with it (they would know the deal obviously.) I feel that I'm pretty mechanically inclined but rebuilding a CRF engine is a bit out of my league and I assume paying a shop to do it would put me out more money than the bike is worth. So, I have this question to ask; what would be a fair price for a pretty dang nice shape 07 CRF250X, with a seized motor with an unknown extent of internal damage?
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By TerryA
      I have two rides in on my new Rekluse auto clutch and I have to say I'm very pleased. The install wasn't hard, but was pretty much a all afternoon sort of project. I also installed a left hand rear brake kit and a two finger cluth over-ride with the adjuster on the perch (which I rarely seem to need). It has all worked great right from the beginning. After struggling to get up a tricky hill in first gear, I tried it in second and the autoclutch helped me clean the hill easily. Not having to worry about clutch action in techinical sessions has also eased fatigue and just made it more fun all the way around. I ride mountain bikes alot, and having both brakes up on the bars has also been nice as it makes for a set-up just like the bicycle - in fact I like that as much as not having to worry about clutch manipulation. The brake on the bar is especially nice on tricky downhill sections where you need to paddle, such as nasty rock/rut stuff. So first impressions are that it was worth the investment -making the ride more enjoyable and easier at the same time!
    • By Mikey560
      I was driving the bike for 15min or so and all of the sudden the bike stalled. I tried starting it again with no luck. I took the spark plug out to see if there is spark so i ground the spark plug to the frame and there is no spark. I even put a new spark plug in the bike and still nothing. Any ideas what i should check??
