13 450 sxf fuel/ignition programmers?
I have a 13 450sxf and was wondering who is using what programmers for it, and their opinions. I want to be able to use a handlebar switch to change the fuel and ignition settings for moto or enduro, the user tool seems pretty spendy and I don't no if you can use a switch with different maps downloaded to it?? The jd sounds great for fuel, but does anybody no if the bike can use a switch for ignition mild/wild to go with the jd?? Any advise/opinions greatly appreciated!
the switch is working on the stock ecu , the jd tuner is not a replacement but only effects the signal that going to your injector , so you can use the jd tuner for the fuel and the switch for the ign. at the same time
Thanks speedboot. What switch are you using for it, and is it pretty noticeable? Three way switch or two? Thanks
  • Similar Content
    • By OffroadMT
      I am purchasing a 2012 KTM 350XCF after wanting one for a year and finally picking one up in December. My question is what are some good things to watch for on this bike as far as initial set up and good Mods to improve bike ? My plan is to add a skid plate, hand guards and muffler with the possibillity of changing the header pipe and a Rekluse EXP would be nice as we ride mostly single track mountain trails with some rocks . Any good thoughts and suggestions would be appretiated
    • By element9
      The story begins with simple installation procedure of a BIG BORE kit that we ordered from USA . The manufacturer (CYLINDER WORKS) and the dealer send us the correct kit and so far so good ! .
      The bike is a KTM 250 sx-f ,2011 model and bellow there are some photos for you, just to see how careful I am throughout the process .
      .. .. .. .. I change the valve seals and the exhaust titanium valves and springs with the PROX steel kit and make a little polishing on the intake and exhaust
      Put the cylinder-piston on and always with guidance from workshop manual and correct clamps...
      Until now we where happy !!! We start the engine ,and everything seems to be ok!
      Began to make the first ride and…… DISASTER !!!
      The engine start bleeding OIL from the hose-tube !!!!!!!!! I thought its normal if it is one-two drops but unfortunately didn’t STOP .
      We did one more ride to see what happens and still BLEEDING. Back to the WORKSHOP.
    • By Dutch84
      I got about 6 months on my 350 xcf-w. I ride a lot of tight, rocky,rutty, slippery single track in South west PA. The only things I've added are suspension, bark busters, skid plate and disc protectors. I purchased a trail tech mapping switch but hesitant to add it as I heard the dealer needs to unlock the ECU and am not sure how much of a benefit it will be. I have a Scott steering dampner I'm going to add. I'm also looking at exhaust options for my riding conditions. What do you guys think about the items listed and what suggestions do you have?
    • By shift1313
      Hey guys, i just picked up a used 2012 ktm 450 sxf to be my supermoto race bike next year. the bike seems pretty much stock but there is a connector on the left side of the steering stem that I am 99% sure couldnt be factory. Its a 4 pin connector, 2 wires in, 2 wires out(to the Estart switch on the bar). On the estart side of the connector there is a small jumper wire in the other 2 spots. I have found lots of info on adding the ignition map switch but i can't find anything about this connector or if it was factory. There is a small coil of wire just before the connector and the connectors appearance makes me think it was some aftermarket or home brew ignition map switch. This is a carb US 450sxf.
    • By riyaadhd
      hi TT users
      i have a flat 11 acre property 20 mins from my house. the property has a pond in the middle of it.
      i am wanting to build an mx track on there, What equipment/excavators will i need to hire. how will i go about constructing the berms, whoops, table tops and jumps. And how can i keep out unwanted riders. How much dirt will i need?
      i would be great if any ones knows track designers and cheap dirt and machine hires. (Dont have much $$ to spend so free or cheap dirt and equipment would be GREAT )
      i am in Brisbane, qld, Australia. Any quarries i can phone to dump free dirt
