Y85 top end overhaul questions
I have a yz85 that im in the process of doing a top end overhaul and cleaning the bike up. Replacing the Sub frame (tweaked) and cleaning the gas tank out, rebuilt the carb with new carb kit, clutch lever replace (ball broke off on end)
2 subject or discussion
1) Anyways I have a service manual and did everything by it. Piston, ring and bearings are within specs. Im wanting to put a hobbes meter (hour meter) on it and I dont know how many hours the bike has on it. I bought it before christmas from someone.
how can you tell on hours? I dont have the guys telephone number anymore.
2) On another subject, when I was riding before the tear down - it was spitting out oil bad. When i took it all apart and was expecting to see ugly things in the bore and ring being broke. Nothing. Its squeaky clean. Im going damn. How can that be?
Makes me think this guy who had it last went 50/50 on the gas and oil. I didnt refill the tank with fresh gas because i wanted to clean everything up and ride. Point is that when i clean the gas tank out, it was pitch black. :jawdrop: I take it because of wrong mixture, it was spitting out oil?
Thanks for your time and sorry for the dragging out story.
hope i can get some answers. Thanks
Edited by Jammj2013
mix 32:1 and jet to that. If it is still spooging then it is too rich and you will need to lean it out, but do not change your mix ratio.
I have new gas already mixed in a gas can - 40:1
  • Similar Content
    • By Rixter
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
