Get that dancing monkey off your back! Read more... ×
Building a 250X for the SCORE Baja Season...we WILL win Calss 20!
As I posted, else-where...here's where we're starting...
An '07 - '13 X with just a few very slight mod's...Air Box opened up, Pink Wire, EPA kit and a pipe w/ Good JETTING...well...it HAULS A$$! This was our "Base-Line" for starting..and it really runs well!
I know, we've built 4 and are working on 3 more...Oh, FMF 2005 R Mega-header w/ FMF '12 X pipe...We are pulling 14-47/48 gearing, too!
We're testing the Hot Cams Stg II cam and a lil' more compression w/ Cosworth CNC ported heads...jus' fore a lil' more...and I'll repeort on those, too...soon.
Btw...
IMS 2.6 tank and Pro-pegs
Renthal Fat-Bars and clamps on STOCK TRIPLES!
Renthal Kevlar grips
Renthal Twin Ring 47 rr and SL 14 frt
Dunlop MX51FA 80/100 frt w/ 739 Dez 110/100 rr
CV4 Batteries, Hoses and Koolers
Baja Designs Squadron, Stator and Volt Regulator
Vertex 13.4:1 Piston (Testing)
Cometic Gaskets
Probably run Hinson Clutch stuff, too, if we get it tested before the Baja 250 (Our 1st race...errr...I mean..."Win"!)
Tear-down and Race-Prep by PowerCurve in Redding, Ca. Get this: Our 1 leged Race-Mechanic is an X-Games Silver Medalist and rides reallllly fast! Todd Thompson
NO "R" heads! No "R" internal-parts are needed! Hint: Found out about a really good set-up from a certain Supercross team THAT RAN X HEADS!!!!!!
We're headed out on Cameron Steele's "Hell Ride" for a little testing/R&D...
I'll report more...later.
Manny
Would love to hear more about the X head that's working so well - and uh PICTURES!!!!
Pics will take a wk or 2 'til I get back to the shop...unbless I get the FBers to put'em up (From our tests at the Vegas 250...where our Truck won the OVERALL!)
Turns out eh CRF-X head with it's longer ports, add'l materials and higher port velocities makes a helluva alot more "Early-Torque" & can have all the "R" needed w/ the right "works"...and it's already won some SX races..and titles...back in '05-'09...
"we WILL win class 20!"
Edited by cb707
Here are my notes post "2013 Hell-Ride" with the Desert Assassins:
About the Clutch...
I'm guessing that Honda was trying to make the clutch very "plush" for the rider; so, it's kinda "SOFT"...spring-wise...
The springs have to GO...stiffer springs are a must.
About the Suspension...
Stock springs are pretty damn good for the 170-190 crowd; however, the valving is better for Moto than it is for Off-Road, W-T-F? We did have 1 of the bikes running a stiffer RR spring (Rate unknown to me @ the moment; but, it's just one or two rates stiffer than stock)...We have a Progressive Revalved set and it's not a whole lot different than our very well "clicked" stock stuff. Forks were up in the clamps 10-12mm.
EPIC turning and still very stable at speed. My 450 is gonna be LONELY!
Good bye ODO/Hello CR axle and seals.
Hot Cams Stage 2 Cam: Better low-to mid w/ plenty more torque at those ranges...HOWEVER...the '07 ('08?) and up motors (Read: CAMS) are actually FASTER on "Top" and just a bit slower to accelerate than the Stg 2 cam. The Stage 2 will get the Hole-Shot...the '07/'08 and up will win the Top-Speed-Rev-Race.
More...later...
Manny
