help with my sisters ttr90 please
My sisters ttr90 runs great, but when you go from neutral to first gear the bike goes on it's own. you don't even have to give the back gas and it goes. anybody know how to fix this? appreciate it!
Sounds like you need a clutch adjustment.
Tighten your clutch cable leaving 2-3mm play roughly. If you don't leave enough play it will ruin the clutch plates.
My bike does this alittle bit. I dont really know how to fix it... all I know is that it is a clutch adjustment issue.
either the clutch needs adjusment or check your idle. if mine is just a little high it will take right off
I didnt know ttr90's had a clutch cable? They dont have clutch's?
They dont have clutch cables. I had a 90 when I started out. Its been 5 years though so I couldn't tell ya what's wrong. It could just be the pull of the engine in 1st that is causing it.
For those of you wondering a clutch cable is usually 10-15mm got the spec wrong sorry.
