2000 RM 250 fork oil
Ya, that link does suk for ya...... The real answer is 454ml of 5wt fork oil. I would put a little less than that in, and then add more through the air bleed with a syringe if you feel the forks are too soft while riding. It's easier to add oil, than to remove it.
Edited by 717 MOTORSPORTS
Thanks. Now I don't have to wait for my service manual to show up. :thumbsup:
who said anything about twin chambers?
Well if they're open bath than fork oil is measured from height not a set volume poured in.
Does anyone have the factory manual for this model? As far as I remember they are twin chamber and take up to 375cc, I used to run mine at 350-360cc to stop headshake, but this is over 10 years ago & I wouldn't want anyone setting their bike up wrongly from my rather distant memory of settings.
LOFGDL!!!!!!!!! And once you measured your hight from the top, why not record the amount, so next time, you can just pre-measure, pour and go? :banghead:
You ran less oil to stop headshake???? Please explain how that works
Minor suspension adjustments like that can make many subtle differences to improve the bike's handling in all sorts of situations.
Yes. As far as I know. A inner chamber and outer chamber.
Show us a photo of the fork, outer tube down and spring off or on. Spring off would be better.
It is a dual chamber I don't know if that is the same as a twin chamber or not but it is a dual chamber. I have already filled the inner chamber I am just looking for the amount about (cc's or the air gap) of oil for the outer chamber.
Thanks for the help everyone
mmm ok then........
