A pissing off problem..2005 Yz 250
I just recently started to put some serious seat time on my Yz after a in depth rebuild, and you can see in my bike Build posts... I have had to split the cases TWO times because of the center case o-ring splitting and coming out of the weep hole.... This is a problem that is pissing me off, has anyone had this problem? Whats a fix> neoprine o-ring and rounding the material around the weep hole to make it less sharp???
Take the case side with the o ring groove and go to your local agricultural or automotive dealer. Get a regular o-ring that is a medium/stiff compound, put a little silicone in the groove and put it together. Haven't had one pop out on me since I did that.
I have heard this is a Reoccuring problem with this model of engine..
