YZ80 / CR125 Build
Well, not a build exactly. The bike has already been built in a backyard redneck way, but it was free on craigslist so I couldn't pass it up.
It has what I assume to be a YZ80 chassis (Can anyone check or direct me to somewhere I can check the vin number in the pic to see what year a model the frame is?) and a 1983CR124 motor grafted into it (going off of what is written in pain pen on the pipe lol, again, can anyone confirm this?). The motor doesn't run, but one of my buddies (who doesn't ride) offered to throw a few hundred at it to see if we can get it running to get him into the sport and see if he likes it enough to buy his own bike.
I just got the bike home tonight. I am going to start off by pulling the carb and giving it a thorough cleaning, checking (and most likely replacing) the piston and rings and flushing the motor to clean out debris and what not. For this would diesel work or is there something better? Then, if all looks to be in place put some fresh fluids in along with fresh gas and a new plug and cross my fingers.
This build/repair will be very very basic. Wheel bearings and steering stem bearings are shot, but will not be replaced, tires are worn and will most likely stay as is. The goal is to just get it running to give my friend some time putting on easy trails and to play with around the house.
Things that will probably be replaced/fixed are:
piston and rings
trans fluid
radiator fluid
spark plug
front brake master cylinder
I'll add to this list as it grows or until the parts list price surpasses my friends budget and we abandon it.
The build will be slow because it will most likely take place just one night a week when the both of us have a few hours to devote to it at a time in between parts arriving from the postman.
Edited by woods-rider
It'll be interesting whether or not you can keep it cool with only 1 radiator.
I have the same concern, but this bike will be ridden extremely easy by a beginner so that should help. I plan on getting some of those thermometer sticker things to put on the side of the cylinder to keep track of the temp. If necessary we will cross that bridge when we get there.
what about just go faster to avoid over heating?longer or looped hoses could provide extra capacity and a bit of room for expansion?
rad cap with a higher pressure rating?
isn't that old 125 motor equipt with the famous magniesium rotting water pump housing?
Where is the tank going to go?
The tank seems to fit. It looks like they made some ghetto spacer piece to hold it up a bit higher. Haven't looked too closely at that part yet though.
Going faster doesn't work well for a beginner who has never ridden before on slimy muddy trails lol.
The coolant hoses are fairly long now, but that is a great idea. I can always add more and zip tie it along the frame in protected places to see if that helps.
I have no idea if this motor has any famous problems or not. To be honest, this is my first two stroke :jawdrop:. I have never worked on a two stroke either so this is a learning experience, but so far it has been a cake walk compared to the thumpers I have had. In less than an hour I was able to remove the exhaust, head, carb, ignition cover, and reed valve. On my WR it would probably take me an hour just to get the head off :banghead: .
Here's where i am at after removing all the above parts.
-No spark. I will test the stator tomorrow and work my way out to the plug. Hopefully it's something simple.
-About a cup of water in the lowest point in the pipe, most likely there is more in the cases also.
-The carb was a little gummed up, but not that bad. A thorough cleaning and it should be good to go.
-The top of the piston looks good to me, but as I said before, I have little knowledge of smokers so any insight is appreciated.
This stator looks OLD... it is older than I am!
Head looks to be in decent shape to me. What do you guys think?
I don't see any major damage on the cylinder walls. Will know more once I get the piston out.
Coolant still in the water passages which gives me hope that it's not totally corroded inside.
Intake port.
Reed valves seem to be in good shape too.
Main goals for tomorrow are to get spark and clean the carb. If we don't have to chase electrical gremlins for too long before getting spark we may flush the motor with diesel also.
So I just talked to the guy who i got it from (didn't see him when I picked it up, it was just outside and had the address on CL). He said that the CDI is bad which would explain why I am not getting spark.
Anyone know what years CR125 CDIs are compatible with the 1983? Or will one from another make/model work?
Worked on the bike for a bit tonight.
Determined that the stator is good.
Took the front brake caliper off because it was dragging badly making the bike hard to push. We will look into fixing that later.
Took the right side engine cover/clutch cover off. The clutch basket has lots of grooving going on so we will file those down. Plates and fibers look good. The oil in there (if you want to call it that) was so thick and dark grey it almost looks like a watery clay material. We will clean this out with diesel.
The cooling system/impeller is just caked in what I have to assume is old dried out coolant? Its super thick and dried up most of the way. It's gritty and slimy at the same time. We cleaned it up best we could with flat blade screw drivers, then our OOPS of the night happened. We were trying to get the impeller off, but to do that we had to find a way to keep the back side of the shaft from spinning. We tried holding the plastic impeller gear (number 5 in the diagram) in place while using an impact driver on the nut... that didn't work out so well and was a stupid move. The plastic gear broke and there doesn't seem to be any on ebay. I think that years 80-84 should fit, but I couldn't find any and they aren't available from Honda anymore. Anyone know where I could get one?
There also seems to be a bit too much play in the clutch hub. I think it may be the bearings in it, but they didn't look bad. I'll look into that more closely once we source a water impeller gear (if we can even find one).
Any help finding a water impeller gear for an 83 CR125 would be greatly appreciated. Would be willing to buy the whole right side case cover also if it came with the impeller since ours has a hole in it at the water pump.
Notched clutch basket.
Inside right half of motor.
Here's the water impeller shaft plastic gear before we broke it. This is the part we need and can't find.
Here's what the inside of the impeller housing looked like AFTER taking many spoonfulls of this junk out!
I dont really think the one rad is a big issue, as its longer than a standard rad and a 125 has larger capacity coolant passages. Good luck on any water pump/case parts. They corrode and are hard to find. Probably the biggest issue facing the rebuilders of these old Hondas is the water pump case isssue
Damn, that's not what I want to hear. Everything looked fine (aside from being disgustingly dirty) until we broke that plastic gear. Right now all we need that we know of is this impeller gear and a CDI. The CDI seems to be relatively easy to find so we aren't going to spend any money on this project until we have sourced that impeller gear.
You'll hate yourself more now that you broke that impeller gear it's no longer avil and it's unique to that year you have to source a used one or try and make a new plastic one yourself. there was some guy outta the uk i think that was remaking the covers in aluminum but it would cost you more then that bike is worth.
Yeah, I am finding it very hard to source. I found a guy in Idaho through craigslist that supposedly has a non-running 83 that he is parting out, but he has only returned one of my emails so far saying that he will check to see if he still has that part.
I do have access to a CNC milling machine so we may try our hand at making a sprocket out of some type of plastic or aluminum. I am a mechanical engineer and use all sorts of CAD software daily, but I am not sure what type of code my friends CNC machine needs. I'll give the Idaho guy a few more days to respond before I get serious about making my own.
If you have to make your own gear there is a reason why they are made from nylon not metal same with oil pump gears sorry i am forgetting why i think has to do with it if fails it won't break the shaft etc
Yeah, but we stripped off all the knurling from the shaft that kept that plastic gear from spinning. I was thinking aluminum so we could do a press fit and it would still be softer than the mating steel gear.
  • Similar Content
    • By Kaito Sutton
      Hey guys, so cant find much online about cr 250r enduro conversions (nothing recent) so im wondering if it is an option or not. I currently have a crf 250x 2009 and a XR 650r. If i want a 2 stroke enduro but want to stick with the honda line up, is a 2007 or 2005 honda cr 250r a good option. and if so what would need to be done to it to get it up to spec for trail and enduro riding. Thanks very much
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By skipn8r
      Note: This specifically applies to the '92 - '01 CR250 engine, but it should be adaptable to any 2-stroke. The basic idea is to pull the carb and exhaust, plug one and pressurize the engine through the other to look for leaks.
      It's very important to pressure test a 2-stroke after it's assembled. The reason is that a 2-stroke gets it's lube through the pre-mix. An air leak means your engine can run lean. Lean means too little fuel. Too little fuel means too little lube. Too little lube means death to your engine. So here we go.
      First, you need to pull the seat, tank, shock, carb and pipe. Everything you need (other than a tire pump) is shown below.
      The assembly below is basically a 1-3/4" PVC plug (same OD as the intake pipe ID) that is transitioned down to a 0-15 psi gauge, a shut-off valve and a Schrader valve (to connect a tire pump). The 1-3/4" PVC plug is a tight fit in the intake pipe, but it'll fit with enough persuasion. I used yellow heavy duty pipe tape (made for gas systems) to put everything together. I don't have all the technical names for everything, but if you take the pictures to a hardware store, they should be able to help you piece it together.
      The item below is an adjustable rubber freeze plug. They are available at automotive parts stores in various sizes, but the closest one I could make work was a 1-3/4" version. You tighten the nut which squeezes two metal plates together which squeezes and expands the rubber piece between the plates. You have to tighten it a lot, but it makes a good seal in the exhaust port.
      Before you install everything, make sure that the piston is at BDC (so that all the ports are open), the spark plug is installed and all other components are properly tightened. Below, you can see the gauge/valve assembly installed in the intake pipe. Make sure to tighten your intake pipe hose clamp tightly as the pressure will tend to push the assembly out.
      Below, you can see the freeze plug installed in the exhaust port.
      Once you have everything installed as shown, use a tire pump to pressurize the engine to 6 - 8 psi, then close the valve and watch the gauge for any pressure drop over a 5 - 10 minute period. A well sealed engine will hold pressure with no observable pressure drop for 10 minutes easily.
      One common "leak" in a healthy '92 - '01 CR250 engine (and probably other types) is through the powervalve linkage. It probably doesn't affect performance, but it'll sure throw your leak measurements off. To avoid leaks, make sure the powervalve linkage is correctly lubed (per the Service Manual) with grease and Moly 60 Paste during assembly.
      If your engine holds pressure with no observable drop for 10 minutes, you're good to go. If the pressure drops 2 - 3 psi or more over 10 minutes, spray soapy water all around the pressure test parts first to check for leaks there. If you find none on the test setup, start spraying the soapy water around the base gasket, head gasket, center gasket etc. Any pressure drop of less than 2 psi over 10 minutes is your call, but I'd definitely fix it.
      I've had really good results by using Permatex Copper Gasket Sealant on the base gasket, PV cover gasket and reed cage gasket. I don't use anything on the head gasket.
    • By ulmanb
      What value would you say a 1986 cr250 with a freshly plated cylinder and new top end, newer tires, newer chain & sprockets, in overall very good condition?
      I picked up the bike (cheap) a month or so ago in need of cylinder replating & top end. Apparently the headgasket blew internally scouring the cylinder. The crank feels good and the bike is very clean/good condition.
      I havent put the bike together yet (too busy to ship cylinder and order parts), but figure I would have a total of $600 (including bike cost) to get it into good running cond.
      A friend wants to buy it as-is for his 15 yr old 200# kid. What value wouldyou put on it in As-is condition vs with a fresh engine?
    • By 150rguy
      Okay so I've been writing this story and been posting it on a different forum, but I wanted to see how TT likes it.
      Chapter 1
      Mark grimaced as his CR85s wheels touched the ground on the finish line jump at Goldendale raceway in Goldendale Californa.
      "And Mark peterson finishes fourth" Mark heard the anouncer say. Mark came to a stop in front of his Dad and Brother, where he handed his bike off to his dad.
      " I cant belive that scumb bag Chris Marvo won again!" Mark said angrily. Mark had been in first for the first 4 laps in the the 80A class but on the last lap, 3 corners the finish line,Chris Marvo had tried to pass him and his back wheel hit Marks front wheel, making him fall. Mark had scrambled to his feet and got his bike started again and finished 4th.
      "I know" Marks brother Tim said "He is such a jerk, If hes gonna pass, he needs to stay farther away, not come in and hug you"
      "Well you ran a good race son" Mr.peterson said " Nextime I'm sure you'll do better." Marks dad had raced when he was younger, but now he was just a pit board hoalder/ Mechanic for his three Motocross racing sons. "We better get your bike back to the trailer"
      They walked to their enclosed trailer and put marks bike on a stand.
      "Nice race honey, are you okay from that fall you took?" Mrs peterson asked.
      "I'm fine mom" Mark said "It wasn't even a hard fall." Mark and Tim walked to the stands to watch their younger brother, Carson, In the Final moto of 65B.
      Twenty Minutes later Mark pushed his little brothers bike back to the pits. Carson had finished third. Marks mom was hugging carson since it was the best finish he had ever had. The kids loaded thir bikes into the trailer and then got in the backseat of the truck.
      The ride home was about 4 hours so By the time they got home it was 8:30 so Mrs.peterson put carson to bed while Mark and Tim took a shower. At 10:00 Mark went to bed not wanting to go to school the next day.
      "How'd the race go yesterday?" Asked Marks best friend Nick when he got to school the next morning
      "Crummy" Mark said.
      "what happened?" Nick said. Mark told Nick all about Chris Marvo hitting him.
      "What an idiot" Nick said
      "You're tellin me"
      Marks first few classes went by fairly fast. At lunch several peopl who had been at goldendale raceway told mark nice job at the race. Marks school was filled with kids who rode and raced dirtbikes. All the MX kids sat by each other at lunch. Together there were around 30 kids who rode in the 7th grade.
      "Hey Mark, are you doing the race at Chadale MX park this weekend? A boy named Kenny asked "Its their first race of the year"
      "Yeah, I think I probably will" Mark said " I bet Chris Marvo will be there. Then I can beat him"
      Sure enough as the weekend rolled around Mark saw Chris Marvo walking the the track with his dad saturday morning before the races.
      "I'm gonna beat that punk today" Mark said as he lifted his bike onto a stand.
      "Just race smart and you'll finish on the podium" Marks dad told him. Mark and his brothers all walked the track, looking at the changes the tracks had made since last year. Then they headed off to the riders meeting. The race organizer talked about the practice order and all that stuff.
      Marks qualifier was the fourth race of the morning. He pushed his bike to behind the gates. All the riders in heat number1 of 85A drew out of a hat to see what gate they were in. Mark drew a peice of paper with a Number 6 on it. He counted out to the sixth gate and pushed his bike to the gate.
      "Good luck" A boy next to Mark said. Mark looked at him and realized it was Drake Thomas, A very fast rider who Mark had never raced against since he raced 85B They year before.
      "Good luck to you too" Mark said.
      The race Before 85A had ended and the card holder was pointing at everyone to see if they were ready. Mark got his head over the handle bars. The card was up. the card was sideways! The gate dropped. Mark pinned the throttle, leaning forward. He was infront but out of nowhere someone got in front of him. It was drake. They came around the first turn. Drake had gottten the holeshot, mark was in second.
      Mark was still in second as he came across the finish line jump. It was just the qualifier to get into the main so mark had not tried to pass drake.
      Half an hour later Mark was sitting under there awning changing his air filter when Chris Marvo walked up to Mark.
      "Hey looser, I see you made it to the Main" Chris said through his yellow teeth "I guess that means Im gonna have to whip your butt in the race again"
      Mark felt anger in side of him but couldn't think of a comback, so he just continued putting the air filter in.
      "Get lost Chris" Tim said as he walked up.
      Mark was getting butterflies in his stomache as The 30 second card turned sideways and the gate dropped. Mark hit the gas. He saw chris come around the first corner. Chris got the holeshot but Mark was on his tail. Mark remained in second behind chris until the 4th lap where he saw a perfect chance to cut him off and take the lead.
      Mark pinned it and cut off chris! He was in the lead. Just one more lap! He kept going in first for the next lap. A few corners before the finish line chris tried to pass Mark for the lead but didn't suceed. Mark felt Chris on his tail. He looked ahead to the next jump. It was a big tripple into a corner. No one in the 85A Class had Trippled it yet, they just doubled it, but Mark had to if he wanted to win. he increased his speed a little! He hit the jump. The ground looked along way away from where Mark was. He came down on the landing and Hit the breaks to slow down for the corner. He looked ahead and there it was. The finish line jump.
      Mark did small whip across the finishline jump.
      Mark High fived his brother and his dad. They expected him to go say something to Chris but he just gave his bike to his dad ad started walking towards the pits.
      After he got his gear off he sat down in a chair under the awning.
      "Nice race Mark" Mark loooked to see who had said it and saw a fairly short man with brown hair.
      "Thanks" Mark said not knowing the man
      "My name is Jordan Styner, Manager of TPA Racing team." Jordan said
      "Nice to meet you Mr.Styner" Mark said politely.
      "Call Me jordan" Jordan said "That was a very nice race you rode out there. I think you should consider joining The TPA racing team as our 85 Rider."
      Mark stared at Jordan Styner. Mark had a few sponsors but none as big as a racing team.
      "Are you serious?" Mark asked amazed.
      "Dead serious" Jordan said grinning."What do you say?"
      " Uhh, Im gonna have to talk it over with my dad" Said Mark still staring at jordan.
      "Call me" said jordan handing Him a card.
      Okay That was chapter 1 guys. tell me what you think
