yfz450 wont run with choke off! HELP!
I recently got a yfz450, extremely low hours, great price, great overall deal. It had sat for a while not running, so, we drained the old gas, changed the oil, coolant, and also gleaned the carb and jets really well. I went to ride it when we were done doing all this and it fired right up and runs great...oh half choke. When I take the choke off it runs rough and then bogs out.
I assume I just need to re-jet for cold weather. I have only ridden it when it was 20F degrees or lower. It usually doesn't get that cold around here, so is it worth re jetting just for a few days that I would have this problem, or do I need to rejet for all weather?
Any help would be greatly appreciated.
ok this is my friends forum topic had him do a favor for me and post on here its my 2007 yfz had 1.4 hours on the motor when i got it on friday took the carb apart cleaned the jets and it rode strong till i turn the choke off it like bogs out and then dies you cant keep it running but with half choke on it runs good and stays running ive did some reading and says maybe its running to lean? anyways by my understandings with half choke your at half the air it usually gets which is the only way its running with half the fuel it needs? anyways should i see if its only the cold the effects it by running it in my heated barn and turn the choke off and see if it stays running? if it does then that says id have to rejet just for the winter and go back lean during summer? but if it keeps dieing id just go with some bigger jets for the whole year? my barn stays at 65-70 and the past few days outside its been 25 or under.
