2006 WR450F Odd problem with idle
When I bought my used '06 WR450F, it didn't want to idle. It wouldn't react to the fuel screw adjustments so I went up on the pilot. I ended up with a 52 which is quite rich for where I ride (sea level) if you compare to what everyone else is using (usually a 48). Bike was still hard to get warmed up and had a rough idle. One day, I noticed the idle improved. I ran it like this for two years.
Last month I removed the carb to install an adjustable leak jet and noticed that the tip of the fuel screw was gone!!! I had remembered that the screw had vibrated loose one day and was resting on the starter. That's probably when it broke off. (yes, the bike did stall). This was the aluminum aftermarket thumb screw. All I had was the oem brass so I put that in. Bike did not want to idle. Sounded very lean. Leak jet was set at #40. Obviously it was working fine with the broken off nipple on the fuel screw so I grinded that off the oem part, put it in and the problem was solved.
This makes we wonder though why my bike is so lean on idle to need a fuel screw setting and pilot jet so rich.
I wonder if I should up on the pilot again to where I can get a new fuel screw to work? I suspect a 54 or 56 pilot might be necessary. That is abnormal for a WR down here.
Either be willing to fix your bike properly or sell it. Doing 'repairs' like you are is just wrong.
Get the tip of the old screw removed from the carb. Have a pro do it. Get a brass or stainless extended fuel screw. Put in a 45 pilot. Adjust the fuel screw for a good idle.
William, let me clarify. What I did was not a permanent repair. I should not have said "problem solved". I should have said "problem identified". I just discovered this issue 2 weeks ago and haven't ridden since. The purpose behind grinding the tip off was to diagnose the issue via the process of elimination. I wanted to see if the problem was the fuel screw or the newly installed adjustable leak jet.
The tip is not in the carb. This is a very tiny piece of tapered aluminum. It could only have fallen to the ground after breaking off.
Please let me restate the question. Could there be something else wrong with my carb OTHER THAN A PILOT JET? Or is it not uncommon for some WR450's to require greater than a 52 pilot jet at sea level?
Edited by Navaho6
Never would be the leak jet. Entirely different carb circuit and does not operate at all at idle (or anytime the throttle is not being opened).
You removed the carb from the bike,. removed the float bowl and are positive the tip is not stuck up inside the brass seat? That is common with the alloy fuel screw failures.
Assuming the tip is not jammed in the seat, that the float height is correct, that the needle jet emulsion tube is not worn out, that the slide is not worn out, that the release plate is intact (and not upside down) as well as the seal and that the slow air jet is installed and the passage ways are clear all that would remain would be having a idle speed too high and having the carb running off of the needle.
Thanks for the help but I think the best thing for me is to send it off to Zip-Ty Racing and have them go through it and check everything out. Might as well have them do their magic to it. I think it is $125 plus any worn out parts.
Sometimes, that is money well spent. Several TTers have atttempted to 'fix' a carb, having not enough knowledge and skill, only to have it turn into a nightmare.
Strike up a good line of communication with ZT and get a good explanation of what was wrong, how they discovered it. Stash the knowledge away. In time, yoo will have the touch to to it yourself.
  • Similar Content
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
    • By husky159
      I have the following to sell...
      215 grip studs with the insert tool. Only 2 rides on them. $70 + shipping
      Stock 17’ 300xc silencer with enduro engineering spark arrestor. (Small dent, a few scratches) $70+shipping
      hyde skid plate for 17’ 300xc in good shape just your normal scratches. $60+shipping
      mikuni 40mm carb with 2-3 rides on it. Includes throttle cable/ tube. Also extra jets and such. $175+shipping
      feel free to ask for more photos
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
