07 KTM 450XC questions
i am thinking about picking up a 2007 450XC with confirmed low hours, a friend of a friend deal, but have a few questions. also im not in the area, so i cant jump on it and take it for a spin. the track near me is doing more and more GP and vet track races now and i want in. i have an ATK 605 dual sport that does well on the street, local trails, on the desert, but if i get the KTM im sure i will only ride the ATK when a plate is required. is the 450XC a good bike for GP and vet track style races? or am i trying to turn a straight line desert bike into something its not? i havent been on a track a awhile, and never raced modern bikes before. im not looking to do big doubles or triples, mostly just vet track riding.
for some reason i think i read somewhere that the 06 and 07 450XC got stainless valves, am i just dreaming or is that what is really in there? anything on a used 07 that i should be looking closely at when checking out the bike? other than normal wear and tear and maintenance items? the bike is completely stock. ive read up on some of the other threads that mention adding a jetting kit because it comes lean from the factory, other than that is anything else necessary to ditch or swap on a stock bike?
my only other "modern" 4 stroke was an 01 YZ250F awhile back, but after sitting on a newer KTM at the dealer i noticed the YZ is not in the same universe as the KTM as far as ergos! and my last KTM was an 89 500DXC, so i have nothing remote to compare it to. i like that a lot of people are claiming its a great do it all bike. what do you guys think of the bike switching from desert, to trails, to MX?
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
