Hulk front brake on YZ125 (CRF + 320mm)
I have 06 YZ125 since winter 2009.
Bike is great but stock braking power is weak.
In autumn 2010 i buy oversize Braking 270mm floating wave disc rotor + bracket.
Stopping is not much better! But disc is new, not worn like OEM.
In 2012 i put 2007 CRF 450R parts: front MC, hose, hose clamp, and caliper+pads
But before few day i sell that system and put a new "monster" setup
320mm Motomaster disc rotor + 2010 CRF 450R front Master Cylinder, hose, caliper (same as 2007 parts)
Here is Motomaster 320mm adaptor for stock bracket, but i sell that adapter and made them (better) homemade :D
Need to make new hole (with thread) on stock 05-07 YZ bracket to use with 320mm
making lower mount support
and ready, steady, go
huge bitch
Stay tuned!
Edited by UNICAM
Holy crap, you have some muscle atrophy going on? I would figure the 270 mm, was good enough, and adding the CRF system (I have that as well) would even kill some factory bikes, but you went 11 here... :thumbsup:
Edited by DrScandinavia
That is nuts!! I bet it stops on a dime now.
no muscle atrophy here. I want 320 rotor, and it is unique. Wait for warm weather to test that monster brake :D
Just don't take it through any ruts or by any rocks.
jes, know that, thanks, no problem.
It has 35mm less ground clearence than original 250mm, ( 25 less tan 270) but i will watch ;)
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
