APT Smart Carb! Anybody Tried One?
these carbs are only for 2stroke.
That explains the lack of information. I think its a little strange that APT doesn't make that distinction on their website...At least that I saw.
these metering carbs may work on 4strokes,it says in there tech info it does.you may have to do some research.http://www.lectronfuelsystems.com/index.html
If it were available as an FCR replacement, I don't see any advantage to this carb on the X, especially for nearly $800. A properly set up FCR performs nearly flawless in a wide variety of conditions and altitudes on the Honda and any other 4T for that matter.
Edited by MasterT2000
I agree with you on that, they have a $350 cast instead of billet carb coming out soon.I do think it has a huge advantage for 2strokes though.mainly because it adjust for temp and alltitude on its own.
On one page it says there's an "FCR side pull" carb. Maybe that would work on the big 4 strokes?
Not temp, just altitude...
I agree, I ride my bike in CA at sea level during the winters in ocotillo and up to 10k ft in the Sequoia's in the summer without any changes or problems. But this carb is cool.
0 ft to 9000 ft without any running issues.
Remember, these 'smart' carbs and FI systems are not that smart.
They can't be without an O2 sensor on the exhaust to monitor F/A ratios.......and a mass air flow sensor, and a corresponding ECU to create compensating maps.
They only compensate for Air Density, but not Moisture, or O2levels, and only by adjusting fuel metering by 5% or so.
It's just an electronic carb.....
  • Similar Content
    • By cmckay4
      Anyone having or had problems with the starter not turning over easily on the 450X???
      I have read about this problem on CRF's ONLY and not seen anyone come up with a fix.
      Problem being is that you think there is a problem with the battery, when infact the battery is OK. When you have a good fully charged battery in the bike and press the e-start, it turns over very slowly.
      I have checked the electrical circuit and it seems OK. I am wondering if it might be the starter itself - any suggestions?????
    • By Dust_Devil
      I'll start, if you see the "Fox Sticker" out in the Dez you know you crossed paths with ol' DD.....
    • By JohnnyAirtime
      Guys and Gals...
      Post your links to any of your pictures in this thread....
      (proper placement of pictures is in the "picture" threads)
      Post your links to any of your ride reports in this thread....
      (proper placement of your ride reports is relative to the area you live/ride)
      NO TECHNICAL issues, questions or comments in this thread.
      (it'll be deleted to keep this thread clean and with only the above listed).
      Please follow this format;
      Ride Report: Gorman, Tuesday 4-17
      (by Skoot22)
      Pictures from Ride: Baja 4.14.07
      (by Johnnyairtime)
    • By dakynz
      Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
      Temperature Range:
      Smog (AIS):
      Airbox Modified Top:
      Airbox Modified Sides:
      Backfire Screen:
      Air Filter:
      Pilot Jet:
      Main Jet:
      Needle Clip Position:
      Fuel Screw Type:
      Fuel Screw Setting:
      AP Modified:
      Leak Jet:
      AP Cover:
      Exhaust Type:
      Exhaust Modified:
      Pink Wire Modified:
    • By 2can
      I've studied the Jetting sticky's but still have a number of questions:
      I bought my '06 a couple of years ago and had a smog block-off kit installed and the pilot jet was upsized to a 48 and the air box opened up top only. The bike has appeared to run a little lean at times and got hot on a couple of occasions in elevation and on one other occasion. I'm looking at upping the main jet to either a 165 or 170 to help with the possible lean condition. The bike currently has a 142 main jet in it which I believe is the stock size. It looks like the most widely used Needle Jets are the JD Red, but it doesn't look like they are sold separately, is this correct?
      I was going to also get a 45 pilot to have options for further tuning. My assumption is that every bike is a little different and that where you ride is going to have a lot to do with jetting. We ride mostly, mojave desert, baja, and southern Utah with elevations from sea level to 9,000 feet but the higher elevations are generally for a short period as we generally continue through the peaks and head back down.
      I'm looking to convert from a stock exhaust to possibly an FMF Q4. I want something a little throatier but not overly loud and will provide a balanced flow of intake/exhaust.
      So can I get the JD Red Needle Jet by itself or can I get by using the stock and move the clip and be just as happy. I'm just looking to enhance overall performance of the engine and maintain reliability.
