Drz turn signals
Anyone ever use the eBay 20 Buck a pair turn signals for ur z? How do u like em? Any recommended signals? I need front and rear. Thanks
Post a link.
If you're off road riding, rubber mounted led blinkers aren't a bad choice. like baja designs.
some people use flush mounted trailer lights too.
I use the 602 fro wheeling cycle supply. If you go led you may need an ic relay as there isn't enough resistor for the flasher unit. Call Forrest at Wheeling he wills et you up. I had them on my DRZ and not one problem. Tell him Goebz sent you.
Cool, thanks! Love this site
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
