Help Identify Possible Fork Upgrades - 2001 DRZ400S
Just bought a new to me 2001 model which I read has the suspension with less adjustment. Mine has adjustment screws on the top and bottom. Forks have stickers advertising a local suspension shop but unfortunately I have no idea what work has been done.
Do these look like stock to you? Thanks in advance
Edited by DRJH1999
Kind of look the same as the ones on my 2012 drz s model .. Dont quote me on that though
Edited by tylerslj
Looks like newer S or E - model fork (old S fork had different cap with spring prelad regulation screw, dunno whether caps are interchangable). But to be 100% I'd look inside.
Later model forks , compression adjustment on the bottom , rebound adj on the top .
Thanks guys hopefully one less thing to spend more money on.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
