250 CR 1994 Fork rebuild : "back up ring" direction ?
Hi, i'm about to rebluid my fork and i dont know the direction of the "back up ring"
The part sits between the upper tube and the il seal , part 10 on the scematic:
http://images.cmsnl.com/img/partslists/honda-cr250r-1994-canada-front-fork_bigecz3l41f__0602_a9a5.gif
It is not the same shape on both sides. One is flat (on the left) , the other has round edges (on the right)
So i can't believe they made it like this for no reason but the manual dont say a word about the direction.
So i can't believe they made it like this for no reason ...
IMO the shape comes from blanking it instead of turning it on a lathe, which would be an accurate plate
purpose is supporting the bushing from the seal rim
Edited by kawamaha
thanks, you're probably right !
But since it also prevents the seal to distort, i'd would be better to put the flat surface agaisnt the seal, right ?
But maybe i'm a bit maniac when working on my ride...
