1991 dr350s overheated and is now having problems
I just bought a 91' dr350s and rode it a bit around the neigborhood. It was running super hot and backfiring alot. I changed the oil because it smelled like gas and I changed the fuel petcock as well. I took it out for another ride and it got super hot again and was back firing alot as well then It lost power and now will not go above 3500-4000 rpm. Any Ideas as to whats going on?
i would prob start by checking flywheel key sometimes they shear and will throw spark timming off ,,then i would check the valve timming and valve lash also then carb
good luck
chris
Edited by tnchris988
Sounds like it might be running lean. A lean mixture will cause the engine to overheat and backfire. Check for air leaks on the intake side.
Let us know what you find out.
