530 EXC cutting out when hot
Just test ridden the bike. Issue is not resolved just yet... So in my view that leaves only signal coil or cdi.
Before she stops there often is a misfire. If i then take it very slowly she will keep running. If i keep the power on she'll stop firing completely within some seconds. While rolling I can twist the throttle but no effect at all. If it were fuel then she'd fire on the injected fuel from the accelerator pump I would think?
Next time you ride your bike, bring a plug wrench. When your bike dies take out the plug and try turning over your engine to see if you have spark. I would also bring a volt meter and when your bike dies, take a voltage reading at your sparkplug cap, battery and coil.
I have a 01 Kawasaki ZRX1200 street bike. My bike ran great until I rode about 60 miles, then my bike would just die. I thought it was bad gas, carburation, replaced handlebar clutch safety switch and replaced entire left side handlebar switch assembly, bike still would die. A very frustrating and long story made short, it turned out to be a bad neutral safety relay on the motor. My bike ran great until the safety relay got hot and then my bike would shut down, no spark. Just sharing a problem that could be similar to your current problem in that something is getting hot causing your bike to shut down.
Good ideas but be careful taking a reading at the cap. There's enough voltage there to cook à meter that isn't on the proper setting, and many meters won't read that high. An inductive meter would be safer.
I had a problem with my '09 530-EXC that would cause the engine to die out when hot also. Tried all the usual things, plug, coil, stator, cap & then a mate & I traced it to the ignition starter switch on the handle bar. Turns out the switch energizes the coil but also feeds power to the starter. The switch is not sealed very well & the contacts were corroded causing the issue. AUS$80.00 switch & problem solved. May be worth a try??
2013 KTM 500-EXC & 2014 Triumph Tiger Explorer 1200
reviving an old thread. my 15 500 XCW is doing the same thing. cannot locate the "ignition signal pickup spool" can you tell me what part that is. can't find it on parts fiche. thanks in advance.
crank sensor attached to the stator
Welp, I finally got around to replacing the pulsar coil. That didn't fix the problem of the bike bogging down beyond 1/2 ~ 3/4 throttle. Guess I'll take her to the dealer.....20170303_125042_resized.jpg
Update: it was the fuel pump. Not even 40 hours on my bike and the fuel pump is bad. Seems to have happened a lot on KTM500s...
Yeah, I think its mostly split fuel filters, its a toss up whether you get a good or bad one. I have over 500 hours on my fuel pump never an issue yet, but it does make you question the plastic fuel filters quality.  Its normally new bikes that seem to get the issue the most.
Edited by Spud786
  • Similar Content
    • By TheLastByte
      Looking for something a little lighter and faster to supplement my xr650l and I think this bike might fit the bill. I'm hoping there are some owners here who can give me some insight into the typical experience with this bike. The question I'm most concerned about is how many hours these engines last before needing a rebuild with normal trail riding? Also, how do they handle in technical terrain? How about on the road?
      The machine I'm looking at has about 75 hours and 1,500 miles on it, all stock other than a lectron carb, and comes with some dualsport lighting not installed. The current owner's asking price seems pretty high at $4500, but he seems to be a communicative, eager seller, which is practically unheard of in Upstate NY where the vast majority of dirtbikes on Craigslist are owned (or "owned") by rednecks trying to flip them. I'm willing to pay a little more than market value for this reason.
      Thanks for any input!
    • By Chad Harlan
      Hi all,
      I got a set of the Axis passenger pegs to fit my 14' 500 exc. The bike does have the alloy sub-frame, but I'm curious if anyone has used this set up with success without destroying the sub-frame or their wife/gf?
      Short trips like errands and rides out to the coast for hiking. 10-15 miles on the longer rides, and likely 0 miles on the highway, as she is not super stoked about riding. But our job kinda doesn't allow multiple vehicles. Yachties. Also shopping a sumo set up at the moment too.
      Thanks folks!!
    • By Bryan Bosch
      Recently,I took a trip out to Colorado for some R&R on a family vacation. I brought my riding gear and had planned on renting a bike, but I was too late and at least what I looked at, there was no availability for my timeline. Bummer, since I'd not ridden the rockies in over 4 years, something pretty special when you live in flatlanderville (Florida)!
      But, behind the scenes, a couple of TT'ers were at work! Through TT, we recently hired a fine, young gentleman to head up our advertising sales team,( @Freemotion ) and he pulled some strings with a local who had a well equipped  KTM 450XC-W that is his back-up machine. His new love is a 2019 KTM 300 TPI and it was gorgeous!
      So, a HUGE thanks to @Freemotion for greasing the skids in getting me a skoot and to @G 9.5 for generously lending out his bike to basically a stranger. The weather was great, so was the company, and the riding was epic as far as I'm concerned. I'm still a bit humbled by the generosity, so I wanted to share a story that I bet isn't as uncommon among the riding community as one might imagine.
      Dirt bike people rock! 🤘
    • By JacksonDRZbeast
      Hello TT peeps. I currently have an 11' Ktm 450 exc which i am converting to sumo. Still on the fence about getting cush drive rims or standard rims. Not too much info on what cush drive does for wheelies. I know its smoother on the tranny and chain but will it make much of a difference with slower wheelies/stunting? I had a DRZ with standard rims and slower wheelies were very choppy and almost impossible to control smoothly. Any advice/tips/help will be much appreciated.
      Also.... will 5" rims be pushing it for chain rub? Should i just stick with 4.25"?
    • By scott72
      Hi, I was wandering if anybody has recently bought or sold a 2014 or 2015 500 exc?  I'm trying to get an idea as to what they worth presently.  Thanks for any help.
