lower clevis swap?
Have 04 rm125 blown shock also have 02 shock in excellent cond.The clevis is shorter on the good shock other than that they are the same,can it be taken off and swapped? Also how is it done?
I would think so, you just unscrew the shaft but you have to set the new one at the right point to get the number of rebound clicks correct, its a bit of trial and error
drop the nitro charge first otherwise you'll have a rebound needle shooting out at you at 150psi!!!
Oops should have stated that ...
