ProCycle Hi-Pro Top End Kit DR650
I just puchased a "High proformance top end kit" with the stage 2 cam (190 grind?) from ProCycle and plan on starting the tare down and install within the next month. I was wondering if anyone had ever done this on their DR and if they had any probs. Mostly what should I watch out for while doing the install and does it require and other mods to work (ie valve springs).
You should search or post the question on the below forum, it's dedicated to the DR650 and is much more active.
http://drriders.com/
