XR600 big bore jetting -- silly rich?
I just installed a 102.4mm piston (and bored XR650L cylinder) on an otherwise stock XR600. It makes for about 660cc, so about a 10% big bore which is not outrageously big. I'm running a stock muffler, stock cam, stock air box (with foam filter), etc. I made no other changes than the piston/cylinder and redoing the valves.
I was running a #65 pilot with the standard bore, which was slightly rich but ran well. With the new big bore it would barely idle and I could bottom the idle mixture screw with the engine still running. I tried a #62, a #60, and a #58, all of which would still idle with the mixture screw bottomed. I verified that the choke is off.
Big bores generally require leaner jetting, but 4 steps leaner on the pilot jet seems a lot. Does anyone have a suggestion?
leaks? make sure everythings is sealed man...
try the classic carb fluid, or use a lighter around the boots etc...
Wouldn't air leaks always make the engine run lean? It seems to be way rich. But I did go back and smear RTV at every joint in the intake system.
What problems would make it run rich, other than the choke?
the reason I say that is it will run if air is entering...lean yes
I had a leak and fuel screw adjustments were nill
thats why I was saying that...
problems
bad comp, leaking valves...plugged up filter or intake, plugged up exhaust
did you clean the headers internally by chance when reinstalling?
my old headers had a few OUNCES of carbon simply fall out of them
scary
jajaja
remove your sparkplug, clean it/ or install new one[preferable] reinstall, run bike abit only using small throttle openings, check plug to see if you are getting a colour to read on insulator, thats presuming you have already cleaned it thoroughly[ the carb], see how that goes,[ ive seen a few of these carbs still run with the idle screw fully shut, ]
Edited by temporarykiwi
