TTR 125 Flooding
Hello I just bought my daughter a 03 TTR 125.When I bought it, it wouldnt idle.I cleaned the carb now it idles fine but floods under part throttle Ive adjusted the floats with no change.whatcould it be.
Check the float level is set correctly,refer to a workshop manual.
If its a plastic float,remove it and place it in warm water to check its buoyancy,if it sinks then replace the float.
Check the condition of the needle valve and seat,if worn replace it.
What did you use to clean the carb with?
