CRF250X: Shock linkage compatibility?
I have a 2004 CRF250X. Is my shock linkage compatible with other model years of the CRF250X, and is it compatible with other models of the CRF motorcycles?
Spud :)
You will need 1 from an 04-05 CRF250X. If you look on yours,you will see a number/letter code cast into the aluminum, this must be a matching
number so as to not change the rear ride height or the progession of the linkage system.
Thank you. :) I wonder if both the dogbone and the rocker are different, or only one of the components is different?
Spud :)
Edited by SpudRider
Both components will be marked with the number/letter code and must match.
Thank you, Chopper. On Monday I greased the lower shock linkage of my 2004 CRF250X. I did see the part code cast into the top of the front part of the dogbone, and the left rear side of the rocker. :)
Spud :)
