Custom Tail Light Option?
I know most people on here probably have the Edge tail light, but for something a little different, I thought I'd try one of the tail lights from, like maybe this one:
Before I buy one of these and make a custom bracket for it... I was wondering if anyone knew any reason why this wouldn't work? It seems doable, I just want to make sure I'm not missing anything.
I used the same set up to make a taillight for my bike. I had to make my own bracket though. I will try to post pictures later
Thanks you guys. I didn't find those threads earlier. :thumbsup:
so i think the only limiting factor is how wide the tail light is versus the width of the rear fender.
so i need a light that is not more than 5 1/2 or 6 inches wide.
Edited by BlenderHead777
As noted I'm partial to the CBR. Later models have a built in running light.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
