Is this a stroker crank?
I'm about 99% sure the crankshaft in the first set of pictures is a stroker crank. Can anyone confirm for sure? The balance shaft looks like it's been polished for clearance with the big end of the rod.
Thanks!
This is another crank I had that's off a different KLX300. This one is not a stroker. Comparing the two, I can't see how the first one isn't a stroker.
Stroker is just a longer stroke. Just measure the two and compare. Or look up the stroke of the factory crank. I think then you would know for sure.
