Adding a headlight to my 300XC
Is it as simple as buying the light assembly and number plate for an XC-W? plug and play? I see open plugs there.
Edited by nofb
pretty sure thats it.
below are all the parts and part numbers you should need.
HEAD LIGHT MASK WHITE 2011 - 7800800100028
BRAKE HOSE GUIDE WHITE - 7800802200028
SCREW FOR PLASTIC K50X18 T20 - 0081050181
WASHER DIN0125-A 6,4 - 0125060003
MASK RUBBER UFO WP '95 - 50211086000
EJOT PT SCREW K60X20 WS=6 - 0017060203
HEAD LIGHT CPL. EXC-EU 08 - 78014001000
Edited by Rex Renolds
Contact Darryl at cyclops lighting (he's here on TT) he can get you set up with everything you need :thumbsup:
Yes. My '12 300XC-w (just like all of them) did not come with a headlight or tail light, so I went to the dealership and bought a new take off head light and tail light for $140 (for both). They plugged right into the loose plugs that you mentioned and work perfect.
What year is your 300 and is a XC or XC-w?
It's a 2012 XC. I assume it must use the same stator?
is a voltage regulator needed?
Only if you want to convert to a DC system. I just did this on my 200 and it gives you many more options (like L.E.D. And H.I.D systems) not to mention accessories like GPS or grip heaters. Enduro Engineering has a plug 'n play AC or DC kit. To convert to DC, you'll need a wiring harness, battery, and regulator / rectifier from trail tech. All together is about $150.
If your bike has an e-start then you already have a regulator/rectifier, at that point lights are just a couple of plugs away.
