High idle Cr 250
my cr 250 idles high when pulling the clutch in or in neutral, but when i ride it the idle is nice and low. any help? i already adjusted air screw but it didnt change much.
try messing with the idle screw and or make sure that you are messing with the air screw the right way. sometimes when its lean it'll want to idle on its own a little bit. and rev a little high... the same can happen with an air leak
Try this
  1. Check & make sure the throttle cable isn't hung up.
  2. Try lowering your idle & see if that helps.
  3. You might need to go one size richer on PJ if temps & conditions have changed.
  4. Check for air leaks if all the above didn't fix the high idle.
REMEMBER EVERYONE THAT IS REPLYING TO THE OP, THAT THIS IS THE SAME GUY THAT STARTED THE "Something about racers makes me wanna..." THREAD. IF YOU HAVE READ THAT THEN PLEASE PLEASE PLEASE DO NOT RESPOND 2 THIS ONE!!! He is a troll!!!
