New valve time?
My right intake is at 0 clearance, both have 275 shims in them. Is that the end of life for a valve in a DRZ or will re-shimming last a significant amount of time?
I have never shimmed them before but I am guessing that they have been done once in the past? (stock shim seems to be 280-285?)
Edited by Vintage Not Pimpage
double post
No such thing as a stock shim size , they vary depending on the actual shim size required .
At the end of the day ... It's time to get the head reconditioned .
Only way to know is to track movement, as this is your first look (a bit late as it;s at zero, which accelerates wear tremendously) Get it back in spec, ride for a week or three and check again.
It moved.... or you get a no start and find zero clearance again,, valves are done
Cheers, ill get the shims tomorrow but I am sussing out parts for a rebuild.
Can prox / wiseco valves be used with stock springs?
Yea they can .
I used Wiseco valves on my bb stroker build .
Is it possible to use the Kw valves with stock springs?
I would not use KW valves ..period !!
Edited by backyard hack
I wouldn't use KW products on a DRZ400 if the parts were supplied for free....
Do yourself a favour and Use all OEM or RHC (ferra) components...
Haha ok, I have found a cheap place for OEM parts so all sorted.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
