Inner cartridge rod assembly
Anybody know if an 07 or 08 cartridge rod assembly will fit in an 2010 kx450. Differant part #"s but not sure if its just the valving that has changed.
if its the part numbers dont match then i would say no.
I don't know for sure.
they changed the bottoming cone/lock ring diameter from 30mm to 31mm on later
models, but don't know if this happened to the 2010 cartridge or later...
Talked to Pro Circuit yesterday. Said need 2010 only, all other years were differant. Their goes $300 bucks.
