problem when bike gets wet
Hey guys on my '02 250 i'm having a problem after the bike gets wet. I'm not sure where the problem is. wondering if anyone has had similar symptoms.
Basically the bike runs fine, I went out for a moto and got really muddy, had to hose the bike off in between motos. Go out for 2nd moto. Bike is running fine. About 1.5 laps into race it sputters and almost dies every time i give it more than 1/8 throttle.
This is not the first time it happened, one time i took it to a car wash after riding and it ran like this afterward.
The next day i go out in the shed, it fires up and runs fine after airing out for a day.
Now i would think if water got in the carb somehow, the problem would not go away until i drained the gas out. this is not the case.
Could the CDI connector or one of those other connectors getting wet cause these problems? I just think its weird because it runs, just not good when its wet. and the other weird thing was that it ran ok after washing for a few minutes before the symtoms started.
I have read posts by Jeekinz saying to put di electric grease on the connectors. I am going to do that, but i figured it would not run at all if this was wet? just wondering if anyone knows exactly what could be causing this as i seem to get the same problem whenever i wash it.
If you are sure you are not getting excessive water through the intake via the airbox, then I'd check all connectors & CDI. If you know someone with a CDI that will work on your bike, try it under similar conditions. I'd start simple...Check the little drain at bottom of airbox, and make sure water isn't pooling up & getting sucked through the filter.
And the plug wire and boot.
My 2000 did the same thing. After washing the bike, or splashing through deep water on the trails. Mine acted like it was misfiring badly after 1/4 throttle.
It is most likely water getting into the electrical connectors.
I used dielectric grease on all my fittings, including the spark plug boot.
I don't have that problem anymore.
Try that first. A tube of grease costs about $5 and it only takes 10 min.
I am not sure why, but those L-series bikes seem to have that same problem.
Dielectric grease all the things and make sure your not getting water into the stator.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
