05 CRF250R rebuild
I ended up with an 05 recently for $500. It was all there, just needed valves adjusted so the PO claimed. Yeah, right. Anyhow, it wasn't locked up, so I paid the fella and took it home. After taking off the valve cover, It was obvious that it had been apart and buttoned back up due to an idiot with tools. He broke the cam wheel trying to pry the chain off, rather than releasing the acct and sliding the bearing over for sufficient slack. But he was right about the valves as the right intake was zero clearance.
I found a new take-out cam from an 06 for $50. I got a ss valve & spring set, lapped them in, and put it all together with new gaskets and a cam chain. I know, I should have put a new piston in, but it actually looked really good as did the cylinder. I thought I'd chance it. I've got exhaust valves at .010 and intakes at .005 now. Cam lobes are facing the rear and all timing marks line up. I've got fuel, spark (new plug), and 65 psi of compression (throttle open, decompressor intact).
It won't even try to start. I took the valve cover off again & checked clearances, they're good. I'm not sure what to look for at this point. Any help would be appreciated.
Does it matter if the crank is on the correct stroke? I don't see how as the timing is set by the cam position.
I'm no pro, so take my word for what it's worth. I believe the crank position (rotation) does matter and I think I had this exact issue last time I did the top end on my CRF. Kicked it over 100 times with nothing more than a backfire or two. Pulled the cam out, spun the engine one rotation and put it back together. Started first kick.
On a four stroke the motor rotates twice to complete all four strokes, so you can be at TDC but if youre out one rotation of the crank the ignition will be firing after the exhaust stroke rather than after the compression stroke. Or maybe I'm totally out to lunch haha.
Edited by sjvmtb
I too wondered about that, but I figured that it was the cam position that determined which stroke it was on. I will try your suggestion tomorrow. Good to know that it solved your issue, so there must be something to it. Thanks for the info.
Btw, where in Alberta are you? I'm in northern Montana, so I've rode at the Raymond track quite a bit.
I think the ignition is based on the flywheel/stator and therefore controlled by the crank.
I'm in Calgary, familiar with the town of Raymond but never ridden the track. I mostly ride trails in the foothills along the Rockies. We've ridden at Kookanusa which you may be familiar with. Usually we go to Maclean Creek or Waiparpous which are just west of Calgary. Hundreds of trails and a lot of fun if you like hills and single track. PM me if you're ever up this way with your bike!
Edited by sjvmtb
Steve, right you were! I pulled the cam, rotated the crank 1 revolution, and it started first kick. That was sweet music considering I bought this knowing it did not run.
I have a buddy in Okotoks that rides at McLean Creek and an area I think he calls Indian Graves? I have also ridden in BC quite a bit at Jaffray & Tie Lake. I'll try to take you up on that offer if I get the chance.
Still needs a few little parts, but it runs well, looks great, and I've only got $1300 in it. I told my nephew he could have it for cost, as he's been looking for one. I'll prolly ride for the summer while he raises the cash.
Thanks again for the tip!
I was recently told my son's 04' CRF250R would not run 180 degress out. His starts really hard the first start of the day. Once going, it runs strong and starts easier. All the timing marks are correct.
You said you rotated the crank once. Just to be clear, from TDC to BDC to TDC?
Wondering now if we are 180 degrees off?
Nice work Jason, glad it helped. Sounds like you got a nice deal on the bike.
A few buddies rode at Indian Graves for the first time this weekend and said it was great. Got a new place to ride!
Jeff, I'd say that if the bike runs at all then the crank being off isn't the problem. It only sparks once per cycle so when it's off there isn't any spark to initiate the power stroke. Are you sure your valves are all in spec? The hard start when cold but good when hot sounds like a valve symptom...
Edited by sjvmtb
Left intake is .003, right is .004, left exhaust is .009 and the right is .011. The seats were cut when the valves were replaced about 10 hours ago.
The timing is good, new piston, rings and cam chain.
Is a leak down test something to try? I do have a fuel screw on the way. Maybe just need to wait for that.
Ah. I saw on your other post that (originally) it was cool out when you were having the trouble. I actually just did the top end on mine too and was having a similar problem - first start was hard but it started good when hot. It was also a little boggy around 1/8 throttle. I put a high comp piston in mine, did you? What I found was that it ran better on warmer days and that the fuel needs changed a bit with the rebuild (I assume b/c of the high comp piston). After some playing around, I ended up with the fuel screw 1/4 turn more open than before the rebuild and that's got it running good again. And I have to twist the throttle 5-10 times before starting when cold. I'd wait for your fuel screw to arrive and see if playing with it helps.
Or if you're antsy to try something, I use a flat bit in the adapter for one of those cheap multi-bit screwdrivers and it fits under the carb well enough to adjust the fuel screw without loosening the carb boots (the thing in the pic below).
Edited by sjvmtb
Jeff, just to confirm, I went one full turn on the crank & installed cam in same position. Like Steve said, I doubt it would run on the wrong TDC stroke or 180 degrees off on the cam.
Steve, thanks again for the help. Here is a shot of the finished bike. I bought a new chain, but it was too small for the larger sprocket. I will have to get a longer one, this one's just plain gross.
  • Similar Content
    • By Brady The Honda Guy
      I recently put a newer style fender and plate on my 2007 crf250r. I just had to drill a couple holes in the fender and I used some washer on the back bolts to angle the fender up a bit. Since the original plate mounted with one bolt in the center and the newer styles mount with two bolts, I had to make a custom bracket. Message me if you need dimensions for this bracket. New style is in my cover photo, stock is in my profile picture.
      So I can get a 1986 cr250 motor for a good price and I also know a guy that has a 2005 crf250r that needs work. I have the idea of just swapping motors. Would this motor fit in the newer frame?
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By ThomasM.
      selling Hot Cams Valve Shim Kit that i bought for my 2005 crf250x, will also fit crf250r.
      used 1x 1.30 and 2x 1.55 shims. the rest is still there.
      $60usd shipped in the usa or canada
      please contact me for pictures or if you are not sure if it will fit your bike
    • By DirtRider250x
      Hi all,
      My main question is how can I make my 250r more reliable. I have owned it for 2 years and it was spent about 1 year in the shed probably needing new valves and piston rings (i have been putting it off) Will steel valves last longer and work well in the engine? Also, what are your thoughts of me selling it and buying something newer? is it worth it?
