Can 2010 side plate fit 09?
Just wondering if 2010 side plates can fit on an 2009?
If not what'd I have to do to make it fit?
No one knows?
It will not fit .
first because of the dual exhaust, which the left side would need more volume .
But you could make that work by getting a single side system like I got .
However, even after you did that, it will not work without major mods,
the subframe is all different, so the mounting points will not line up,
and keep in mind that the airbox and rear fender do not flow with the plastic you want .
So you could fix that too, but again, thats a lot of work,
and the result is not that big of a change if you think about it .
