2005 KX250F Hitting rev limiter at 1/4 throttle
First and foremost hello everyone I'm Steve thanks for viewing and offering any helpful insight. A little background so everyone knows I bought this KX off craiglist for 800 bucks starts wont accelerate.
Heres the haves
After cleaning the carb thoroughly and reassembly problem still persisted so I proceeded with the following
removed cylinder head check that the piston was in the right direction
Checked valve clearance and re shimmed as needed
Retimed the motor
replaced the upper gaskets for air leaks
replaced both exhaust gaskets the one at the head and the one at the slip on
re built the carb all new gaskets, jets, needles. Settins are 42 pilot 180 main 3rd clip from the top on needle 50 leek
New Pro circuit aluminum hot start connector to carb sealed.
sprayed the motor with starting fluid to check for air leaks around the carb or gaskets
Here is my problem Bike fires instantly first kick every time choke on first start of the day never needed again. Idles like a pro idle and 1/8 throttle perfect as soon as you break 1/4 throttle it hits the rev limiter.... or so it sounds there is no way this is carb jetting or timing or clearance.
the muffler has 3, 1/4 size holes in it midway were some fat ass bottomed it out and hit the rear caliper. ( I believe them being in the muffler would not cause this ) I am leaning towards CDI or TPS maybe crank sensor anyone else heard of this seen it? Any ideas?
when you cleaned the carb did you take the tps off? its a star bit
No as I did not fully submerge the carb I only submerged it 3/4 of the way then sprayed it out with carb cleaner In the can before blowing it out with air. The basket was hung as to not let anything below the needle jet soak. I do have the torx bit capable of removing it. I also tried running the bike with the tps un plugged it fired and ran fine at idle but once again it wouldn't rev past qtr throttle without sounding like it hit the rev limiter.
my guess is that its probably just backfiring real bad making you think its hitting the rev limiter. Did you take a look at the accelerator pump diaphragm when you had the carb apart. I had a similar problem and the diaphragm was leaking.
New diaphragm I rebuilt everything in the carb.
The slide plate can be installed upside down in the carb and will cause very erratic running, most times the bike won't rev. That would be my first check. There is also a lower rev limit while in neutral so if it does it in gear that switch might be something to check as well.
can you get a video?
Got one on my phone how do I post it is it possible through the app?
Never took the slide plate off when I removed it
Here's the video one kick start choke off
Doesn't mean it wasn't installed wrong before...... Never assume.
?? Nothing
Did the video work?
Really cannot get video to load. I can email it.... Quick update checked the slide plate to manual it's on correctly. Checked the tps to the manual it's in the right voltage. Checked the stator ohms only because it won't rev high enough to check output. No short in the stator.
Make sure your crankshaft isnt twisted. Check TDC actual (piston location) and on the timing mark.
Just the final update pulled the exhaust muffler off all packing burnt off or taken out by previous owner. Basically like a short extended head pipe causing it to run way to lean re packed. Re adjusted carb to normal settings runs great. Thanks everyone for the help!
