supermoto midvalve
Does anyone run a clamped mid valve for an tarmac only supermoto bikem?
you mean like no float?
Depending on type of fork, I have used different zero float schemes for my supermoto tunes. Sans check spring, I've worked with different shim thickness and taper. I don't use zero float on 10 and later yz450s; .1 works well on those.
No spring in mv . There are many options with taper. You can pm me and I'll see what I did.
