New DS switch - no spark
Hoping someone has an idea of what I can try next.
My old Baja Designs switch has been on the fritz, so I finally ditched it for Tusk switch from RMATV (similar to the new Baja Designs switch). BD says you need to also buy an additional wiring harness (for $$$$$) to upgrade to their new switch. I have a hard time believing this can't be done easily without the new harness, so I opted for finding my own 'logical' solution.
The plan was to simply match up the wires (functions) from the old switch to the new switch. I have instructions/diagrams for both.
Big mistake right out of the gate: did not start the bike up this spring before snipping the old switch. So, I have no idea if something happened over the winter while sitting (garage at the cottage). Except for an intermittent lighting problem caused by the old switch, t was running perfectly when put away.
Wiring: the old switch had 11 wires, the new switch has 8. Two of the extra wires are for the kill switch. By simply connecting these together temporarily, that should close the circuit and allow starting/running. Continuity tests back up my assumption. The third wire is "Accessory Power Out". On the old switch, this worked in the two "On" settings, and had no power on the "Off" setting. The new switch doesn't have an off setting, so I assume that can be wired to the main power input to the switch?
I unsuccessfully tried starting it many times. No luck. Pulled out the spark plug and checked for a spark - none. Re-gapped and also tried a new plug with the same results. Re-checked the wire matching MANY times to ensure it was correct. Have checked continuity in all switch wires. Have tried disconnecting the extra accessory wire with no luck.
There is a few volts of power coming to the main power input to the switch from the small battery pack. It hasn't been re-charged, but I assume shouldn't need any power to get spark, as that will be coming from the stator. It just needs continuity. Please correct me if this assumption is wrong.
Any ideas on the next step or input on any of the above wiring choices? I've been working on this for two days, and getting frustrated :banghead:
My apologies if I do not understand your post................I would suggest that you disconnect the kill switch wires. I am not familiar with the intricacies of the dual sport switches, but the stock kill switch grounds out the ignition spark when pushed in. So I would guess that your old switch connected those two wires to kill the bike instead of disconnecting them?
Figure out the proper wiring for the kill switch wires, then.......
you have to at least drain the carb float bowl of the old gas that's been sitting in there all winter. There's no way it's going to start with that crap in there. You most likely also need to at least pull the fuel screw and clean / blow out that passage with some carb cleaner. Make sure you account for all parts, screw, spring, washer, o-ring in that order. Check the condition of the o-ring. It would be a good idea to pull the float bowl and remove and clean the jets too.
I sure do not want to argue with Trailryder42 as he provides valuable help daily. But I would not touch the fuel system until I could prove a good spark and the bike still did not start.
While it is certainly not recommended, I recently pulled out 2/ XR4s that had been put away wet and not run since August and they both started right up. One with stock carb, one with Mikuni TM36.
Thanks for the help everyone. Confirmed that it was the kill leads!!! I thought I had checked voltage with them connected and not connected. Must have been testing other wires. Should have had a physical checklist.
Retested and confirmed that there was only voltage to the main switch wire when the kill switch leads were NOT connected. Kicked over again with the spark plug out and voila!
My winter storage system involves emptying the float bowl, adding fuel stabilizer, then re-filling the float bowl, In the spring I empty out the bowl again, and re-fill. It's worked for the past two winters without issue. I'll wait until it gets a bit warmer out before firing it up for real (still about 5C here), but confidence is high :)
Cheers!
That's the way to do it.
If you don't say tho, I'm going to assume otherwise.
Cheers!
No offense taken, I know you're just trying to help by covering all the bases :thumbsup:
It took a few more kicks than I'd care to admit, but it started. Still quite cold out, so I'm chalking it up to that. Purring on all cylinder now though. I'll post up the wiring mappings tomorrow for a reference in case anyone else is interested in doing the conversion. Also so I have an online copy for myself :D
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
