xr100r engine fouled badly
so i got a xr100r about a year ago as a first bike, and after i got better at riding and mechanics i noticed it was putting out way less power than my brothers little 70. so i decide to tear it down and it turns out the whole valve and head was badly fouled and so was the piston. i also accidently stripped a bolt off in the process on the head. will i need to buy a whole new head assembly or can i just clean it all up and keep going? also how much do you think it would cost to get these parts cleaned and redone?
looks fine to me, maybe running a little rich.
in your diagnosis for lack of power, what was your compression reading? Leak down spec?
i dont have the right tools to check compression, but it was under what i would have expected for a 100 need in ways of compression. when i say "badly fouled", i mean its completely covered in carbon buildup and needs to be cleaned very badly but i dont no if i will mess it up if i take a wire brush to it and clean it off.
Edited by mxchri5
ya i thought it was fine but i want to clean the head and i dont now exactly how to do that without damaging the actual valves, and i dont know if i can just take a wire brush or if i should take it in and have the dealer do it
I looks absolutely normal to me, very little buildup. If you want to clean it up a little that is fine but unnecessary. Anything you want to use for cleaning is fine, just don't mar the gasket surface.
As long as you have it apart you might put a set of rings in it. Turn the head upside down and fill the combustion chamber with liquid and leave it that way for a while to see any leaks past the valves. If it does then you need to have the head looked at by a reputable mechanic.
okay, ya my dad kept saying that it needs a bunch of work but i keep looking and seeing it needs less and less, i still need to get the bolt out form the head cover that i accidently stripped out and do you mean rings for the piston or gaskets?
i tried that ricj to put water in and the water started to pour out of the intake hole in a pretty good stream, i guess when i get time ill have to go dowon to the dealer and have them look it over and see what i need to do
I meant replace piston rings and check valves and seals while you have apart. Gaskets go wthout saying..
Judging from your pictures it looks like it was not burning oil excessively or looking anything other than maybe slightly rich on fuel mixture. But as long as you have disassembled it you might as well freshen it up while you are there.
ya thats what i was going to do and maybe put in a couple of upgrades while its apart, but i dont know. i want to try and put the bbr big bore kit on it since its a good deal for how much i want to actually put into it and i also noticed the clutch cover had cracks that started to go all around the part where the clutch adjust lever would press on it and i need to replace that before it goes through the cover
Edited by mxchri5
you could try lapping compound on the valves, about 6$ at an auto parts store, just need to take the valves apart(easy).
Take the head to the bike shop you buy the rings and gaskets from, they will do the job for you.
maybe, but i don't have the tool to get the valves apart yet and i don't want to do it by hand
look for homemade spring compressor ... basically you just need to bent a metal bar 2 time so it form a U shape then you compresse the spring and take out the little thing with a magnet how a pair of long nose
  • Similar Content
    • By Daniel627
      A while back I picked up a '95 XR250R swingarm that I plan on installing on my '90 XR200R in the near future, to save a little weight and have rear disk brakes.
      I missed out on a totally complete rear brake system for $75 a while back which sucks. I look on Ebay every now and then hoping to find a great deal on a complete or near complete setup but no luck lately.
      Is anyone aware if Honda used the same brake system that was used on the '90-'95 XR250R, on any other bikes?
      If so, then I can expand my search. If not, then I'll just keep looking at 250 parts til I find the right setup for the right price.
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
