Help with Clutch, maybe?
Should there be tension on this shaft or should it just free spin from stop to stop?
Background: I don't even know where to begin. I've looked in the manual to see what this part is called, but I can't find it. In my mind it should in some way disengage the clutch since it's at the end of the clutch cable. I'm thinking it should have tension.
The bike felt like the clutch was fluttering or the chain was dragging, but the chain tension was good. It wasn't at any set speed, set RPM, or any time; it would just happen anywhere from 35-65 mph. I came home with the bright idea of adjusting my clutch cable. I popped the end of the cable off that shaft and now the shaft just flops. I don't want to open the case up if I don't have to. I drained the oil. There was no big shavings on the magnet, just standard minimum of gray metal sludge barely covering the magnet.
Any help is good. I have a factory repair manual with a so-so tool kit, but I want to make this as easy as possible.
Get a new gasket, some fresh oil and filter. Seems like a good excuse to do the loc-tite fixes. If you go to bike bandit they have pretty good schematics for your bike.
But then again, do what Noble is going to post too it will probably save you some money and mess.
Edited by whyfly
That shaft is a cam that pushes on a rod that releases the clutch. Turn it CCW until it stops. Put the lever on and tighten the pinch bolt so it can't slip. As the cable pulls it further in the CCW direction, it will release the clutch. It is normal for it to be free as you twist it back and forth with your fingers up until the point the cam contacts the push rod.
Do this.
I had this exact same "problem" about a month ago. There is tension but your fingers aren't strong enough to push the push rod. Once the cable is on, it will give you enough "lever-age" to turn it.
Take a look at my started posts to see the one I started about the same thing.
Edited by imnothng
Thanks, I believe this was not such a big problem and is fixed now. Thanks for the replies, definitely helpful. Now I just have to put it all back together and see if that helps with the noise. Thanks again.
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
