Yoshimura rs4 fitment
I have a buddy with a 2009 kx250f and he was wondering if the yoshimura rs4 fits on the 09. It fits 10-12 so why not the 09. They're all the same general shape. Thanks!
09-13 pipes will fit anything in betwen- 09 10 11 12 13 all use same pipe as far as mounting, some pipes coming out now may be MORE 13 specific do to the power charactersistics of the 13 but none the less will still "bolt Up" to the 09.
  • Similar Content
    • By Robert Rice
      Okay so I picked up a 2018 kx250f the other week and took it riding and it was BAD ASS! I have a 2002 ktm125sx and it’ll whoop that thing any day! I’m going to the sand dunes this weekend and gonna use the 6 paddle I used on my 125. Should I be using an 8 paddle with a larger rear sprocket? I wouldn’t want my first experience in the dunes on this bike to be a bummer just because I had the wrong paddle on.
    • By TPA-MX
      Hi guys,
      I have a 2014 KX250f that has a super small hairline, I mean super small hairline crack just under the main engine plug hold on the ignition cover.  You cant really see it, but it "slowly" will leak oil out if let set long enough.
      I would like to permanently fix it.  Right now, I just used some clear silicone on the outside and it stoped the leaking.  However, looking to sell the bike and I want more of a permanent fix.  The 3 options I see are:
      Replace just the ignition cover Replace the entire Stator/ignition cover Use some jb weld on the outside, sand down and paint My questions are:
      On #1, how hard would it be to use my existing stator / magneto items and install in a new cover? On #3, can JB Weld be grinded/sanded down to a smooth finish?  If so, what is the best material to use?  Regular wet/dry sandpaper?  If I go this route, I would want it to look decent, then paint the entire cover black with hi-temp black paint.   What would you recommend?  Am I missing any other alternatives?   Thanks!
    • By rollin30
      I need a subframe for a kx250f and an exhaust system too
    • By rollin30
    • By Andrew Oberther
      I picked up an 09 kx250f as a winter project and it had a chewed up head, and is unrepairable. I was online and found a 2011 kx250f head and was wondering if it would fit. Thanks.
