RM85 gearbox reassembly question (shifter cam)
I'm reassembling the gearbox and would like to know the proper procedure for aligning the cam (item 6) and shifter forks (items 1, 2, 3) as referred to in the diagram linked below. I assume the cam has to be placed at a starting position so the gears can be sequenced properly. Thanks.
http://www.partzilla.com/parts/search/Suzuki/Motorcycle/2006/RM85/GEAR+SHIFTING+%28MODEL+K2-K3-K4%29/parts.html
So the cam can be placed at any starting position (12 o-clock, 3 o-clock, 6 o-clock) as long as the shift forks fall into the grooves on the cam? I guess I expected the cam to have a rotational starting position. This is my first gearbox teardown.
