stator failure #4 or 5, i forget
I have got to be doing something wrong, failure of stator number 4 or 5 in 3 years, today.
oil changed every 1000 miles, free power mod, usually very reliable otherwise.
I'm fixing this, selling, and looking for an xr600.
this is in no way a slam of the drz, its a great machine I'm just done with stator failures.
What are the failure mechanisms? Just getting too hot and burning up? OEM or aftermarket?
i've had 2 OEM, 3-4 ricky stator. all are -not- higher output models.
i'm not sure what you mean by failure mechanisms. they quit charging the battery, i test, usually it's a short to ground.
You've got to be doing something wrong as your the only one suffering with that many bum stators.
i'm all ears as to what it is:
oil/filter changed every 1000 miles (that's 22+ oil changes so far)
original clutch (hard to believe, but true)
i've seen the light (over temp) come on once in 16000 miles. yes, it works.
radiator fan works
coolant is clean and changed twice a year
never popped a fuse, headlight bulb, turn signal bulb, brake light, or had any electrical connections get warm. free power mod completed.
again, i'm all ears.
Can you link to any threads which document any of your previous failed stators?
where you ride, what temp is it normally, do you do sustained high revs for long periods?
what oil type/brand do you use.
Do you ride with your head light on?
Edited by DrzDick
Is it a bad idea to ride with it off? I made a blackout switch for trail riding meaning no lights at all.
Have you changed the flywheel to an aftermarket one ?
I think so.... but not always..
I don't have my headlight on while trail riding but I'm generally at low revs picking my line through..., unless it's a wide open forest track. :ride::jawdrop:
The higher your revs the more power your making from your stator. The more unused power you have the more the R/R shorts this power back to the stator to stop the voltage from harming your bikes electrics. The stator is both the generator and resistive load. Once the power demand of the bike & battery is met all spare power is dumped back into the stator which turns it into heat in the stator windings and finally is absorbed by the engine oil (which is already very hot).
If your at low revs then turning off your headlight will ensure your battery is topped up, if your at high revs (crusing on the highway) then running your headlight will ensure that there is 55 watts of heat coming from your head light and not heating your stator.
Edited by DrzDick
  • Like 2
No, I've had five stators as well. three OEM, one RM Stator and one Ricky Stator. All but the first were installed using the guidelines found here. I use Silkolene Ester based synthetic as recomended by Eddie, oil changes rarely exceed 1K, free power mod, headlight working, in-line volt meter stays between 13.8-14.5 volts (the lower reading when my heated grips are on).
Edited by Drz Charlie
No, I've had five stators as well. three OEM, one RM Stator and one Ricky Stator. All but the first were installed using the guidelines found here. I use Silkolene Ester based synthetic as recomended by Eddie, oil changes rarely exceed 1K, free power mod.
Okay...
There must be a common failure pattern linked to either use or maintenence (or other reasons) because these bikes are not known the eat stators.
Typcally an OEM stator should last approx 15-20K miles?
i'll have to link to the other threads later... just a quick response for now.
40f - 100f depending on the season. i usually turn the bike off instead of idling in a mud pit, and if the fan is on, allow the fan to run (key off) until it shuts off on it's own.
sustained high revs, i don't have a tachometer, but there are times it sees highway speeds (21/18" wheels with 15/44 gearing) and occasional interstate speeds. i doubt the oil gets any hotter than a single track bashing.
oil, rotella, or delo, whichever is on the shelf
head light on all the time except single track (low, slow speeds).
i never have any trouble with clatter or detonation (that i can hear) and the radiator has boiled over once in the last 3 years, when the fan was crushed.
Only common link I see so far is the free power mod. I've never done it myself but was wondering if there is a way of doing it wrong that would cause this.
i would think the main fuse would blow if anything was done poorly, or the wire would get HOT fiarly quickly.
it's just deleting the crap suzuki connector.
no, the stock flywheel does what it's supposed to just fine. besides, there were all those people having trouble with aftermarket wheels i skipped it. stock (usually) is more reliable. usually.
usually. ;-)
some of my rant threads while changing other stators:
http://www.thumpertalk.com/topic/903471-another-damned-stator/
http://www.thumpertalk.com/topic/918152-2004-drz400-will-not-start/page__st__40 (this one is really long, but i ringed the piston and took beautiful pictures)
http://www.thumpertalk.com/topic/988000-ricky-stator-vs-ebay-stator/
i believe this makes stator number 4 in the bike, and 5 being re-wound at a local shop as i type this.
so, we're on #5 when i install it wednesday. 22,500ish miles on the bike.
Just throwing this out there... Maybe something is mis-machined where the stator is held and it is not positioned correctly, or something odd about the regulator...
Have you ever had to replace the regulator?
I would be a little (actually a LOT) frustrated if I had replaced the stator that many times. Something is very wrong.
( I'm still on my original stator and I keep my fingers crossed that it continues to keep doing it's job. I run 2 - 35W HID's all the time and heated grips during the winter. Not to try and jinx myself, but by Friday my bike shjould hit 70K miles...)
I suppose it's possible that it is mechanical stress - that was mentioned before as a possible cause.
I wonder if the stator is moved over slightly whether it could have some kind of megnetic imbalance that give rise to small vibrations within the windings and lead to shortened life...
It could account for how some seemingly identicle bikes can suffer from failed stators while others don't.
The electrical system should not be able to harm the stator. The worst thing a short could do would be to short out the stator, which is normal anyway but a R/R will never short a stator out for long - it just clips it.
Maybe a bad R/R can short the stator for too long, or somehow also short the battery out through the stator as well - a freak condition that shouldn't happen (and I'm not sure if it's possible).
ohgood & Drz Charlie - have you changed your R/R's since your bikes started eating stators?
The first thing a stator connect to is the R/R so I think after a couple of early stator replacements I'd start to wonder if the R/R could be causing it.... but how.. I have to hit the sack now but I will ponder this..... :thinking:
Edited by DrzDick
ohgood - My questions:
1) Do you have a case protector glued to the outside of the stator cover?
2) Have you ever talked to Ricky Stator about trouble shooting or repair or replacement?
3) As DrzDick points out, the electrical system is designed for lights on all the time to use the power generated. Why turn the headlight off?
Stators fail from heat. Questions 1 and 3 contribute to heat. My theory is stators cool primarily from conduction to the case not by oil.
DRZ Charlie - How are you doing with your current stator? Is this one a winner?
DrzDick - Is it possible the stock flywheel has stronger than normal magnets? Increasing the output?
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
