Xr400 or or Xr250?
How big are you, and what kind of riding?
250r is better for the tight technical stuff.
XR400 if you want tractor like bottom end torque. :thumbsup:
Edited by 0macman0
I just upgraded from a xr250r to a xr400r. I am 16. I am 185cm tall pretty strong. My 250r was a good fast bike. My 400r is twice the power. ALSO FOR SOME PEOPLE ITS TWICE THE WEGHT OR FEELS LIKE IT. 250r quicker through tight. 400r quicker in general.
16 years old, 11 years experience, already have a CRF250X, it's just going to be my play bike. I was going to get a 125 but I like the XR because it's more of a trail bike. I ride desert.
I'd agree if they weren't so heavy. Haha. I'm thinking the 400. Its just going to be a bike for really tough terrain and stuff like that and so I have an extra if I need it.
250 has 6 gears which is nice. The tighter and more technical the trails, the better the 250 is. The more open the trails, fire roads, sand, the more power you're gonna want and need. So 400 would be better.
How much do you weigh? I'm only 145 so the 250 scoots me around pretty darn good.
Tough choice still lol, at that weight you could go either way. I think the 250 will be easier for you to throw around nd a tad more fun. My buddy is 210 and he always liked the 250 but when we'd race it and clock times... Hah, he knew a 400 would be the ticket for him!
So more power, but more weight.
Or less weight and more maneuverability.
the 400 is maybe 20 more pounds and has monster low end torque. i love my 400 but wouldnt mind having a 650r for some more un-needed power to play with. the 400 would be perfect with 6 gears!
I would rather have the 400 on the highway, but in the dirt, the 250 is lighter. The 250 has plenty of low end tractor-like power to climb anything you can get traction on. Add a four gallon tank and you have a 240 mile range. The 250 is a lot easier to kick start.
I just did a ride with a 400 and a 650 on my 250 and I can ride as fast as they are willing to ride and faster around corners on dirt roads. Tight trails are easy on the 250, though the 400 does really well with a strong rider.
The 250 won't wheelie or break the rear tire loose with a twist of the throttle like the 400. I think that is the biggest difference.
I have both. For the tight, technical stuff around here... I generally find myself on the 250.
If you're over 6ft tall or ride more open terrain, you may like the 400.
Good Luck!
  • Similar Content
    • By 661Bran28den661
      What’s up guys. Totally new here picked up an XR400R I live in the desert so I’m riding often and enjoy it. But I am having some issues with my  01 XR400R. I brought it out this morning for a putt and it seems to be choking up in the top of second. Like a bog an go bog an go. First seemed fine and third I didn’t make it high enough into the rpms to see. Before I brought it back to the garage. Yesterday I also changed the air filter back to an uni. I had seen the other one had a hole in it and the box was dirty gunned up and oily. I removed the airbox gave it a good clean out wiped everything down very well put a piece of screen over the snorkel Or where it used to be I should say. “Lightly oiled the filter.Also the spark arrester an tip for the bike it did not come with I ended up making one with a piece of flat steel and drilling holes. Whilst doing this. I found also a crack in the pipe. It almost sounds as like there’s a vacuuming or whistle? When revving.The first one I had made worked fine I had no issues. This one I am wondering maybe if it’s a cause of a little too much back pressure.So I’m assuming it’s either a Carb or exhaust problem. Or something that could totally be minuscule. Or major issue. Would definitely like some second opinions and any advice would be greatly appreciated. Thanks guys!
      TWISTIN THROTTLES & CRACKN BOTTLES
    • By ddickinson
      My lanky 14 year old boy started showing an interest in riding MX/Off-Road so I sourced the best beginner friendly, yet dirt worthy, bike I could find: an Ol' Honda XR250R (2004). So far I've replaced a few clutch levers and perches with stock parts. That's gotten old and I'm looking to upgrade to an ASV or Torc1 type fold-able clutch/perch brake combo. Went to purchase online today and to my surprise there were no such parts listed for the XRs. I saw plenty of CRF/CRF-X choices and they seem to differ depending on generation. Obviously I can use nearly any perch/clutch combo as long as the two match; but I was wondering if anyone knew which of these levers was closest to stock? Also, will the first gen CRF250X brake lever work on the XR? These may be stupid questions to some; but I'd rather ask a dumb question than drop money on an ASV brake lever I can't use. Thanks for any help.
      #xr250r#hondaxr
    • By TheLastByte
      Im currently in the market for an xr400r, and considering buying one that's had some heavy engine work done. The current owner claims to have bought it from a friend who's an XR enthusiast. The PO installed a big bore kit and high comp piston, as well as a xrs only pumper carb, rsw triple clamp, aftermarket clutch, street lights, and a whole bunch of bling.
      My main concern is the effect the upgrades will have on the engine's longevity. How much quicker will I be going through top ends with the setup on this bike as opposed to a stock setup, and should I be worrying at all about bottom end longevity as well? I wouldn't mind having to eventually redo the top end, but I don't want to deal with a race bike type top end rebuild schedule on an XR.
      Is there anyone here who's running a bike similar to this one who can give some advice?
    • By Ralph303
      I have a 2001 Honda XR400R. It has a whirring/grinding sound in the lower end and a vibration in the top end. I pulled the valve cover and everything looks good. Decompression lever looks to be in order. Anyone know where I should start looking or just rebuild the whole engine. Ballin on a budget, but really love this bike. It looks like it’s new otherwise. Oil was jet black and thin. Thanks in advance!
    • By junglePIG
      Hi, I have an Xr250r with a buckled/ wobbling front wheel, after trying to true the rim i have broken a spoke.
      I am wondering if it is possible to lace any 36 hole aftermarket rim to the oem hub, also will i need to buy an xr250r specific spoke set. also could i take a 36 hole rim from another front wheel and lace that up???? thanks
