Kx 125 carb
Okay on my kx 125 it runs fine but when I lean the bike over gas runs out the over flow tube what does that mean and how to i turn down the idol speed is it the screw on the side with the nut
How far of a lean?
For the idle, you have to loosen the nut. It's a jam nut. Once you set the idle to desired setting tighten jam nut.
  • Similar Content
    • By Shawn658
      I am trying to find out if the water pumps for the KX250'S will interchange. Seems most parts from 96- 07 will. Can anybody help me out? My plan, put a Boyesen Supercooler for a "05" model on to my 99. Will this work? Any help is appreciated! Thanks
    • By Daniel Wolfe
      So i know my way around a crab pretty well and i'm very familiar with them i just can't seem to get the kawi dialed in it seems to have this unging/erratic rev thing going on when i pull in the clutch and i slow down so i'm looking for the correct carb adjustment for the bike it didn't seem to do it when it was warm out but now that it's in the 30's forties it's doing it my elevation here in upstate ny is 295' it's been around upper 30's lower 40's but i'd like to tune it so it's ready for summer because i don't ride it much in the cold so i'd like to tune it so it would be best in 70-90 degree weather since that's pretty common around here So could someone please help me out I need to know what the fuel to air mixture is needle position and proper jetting thank you
    • By Henry Nichols
      Okay guys, I have a 1997 kx250 frame and I wanna know(if even possible) if there are any 2 stroke engines besides the original that will Bolt onto the frame without any modifications.
    • By Alex Seprish
      Hey guys I have a 1991 kx125 and it needs a crank but you can not find em anywhere so i need a good cheap place to get it rebuilt if you guys know any place let me know thanks
    • By DirtBikeHead
      Beautifully restored 1996 Kawasaki KX250! Hard to come by them likes this... has a ton of nice upgrades, including:
      PC (pro circuit) linkage
      PC valved suspension for 190 lb rider
      Rare PC seat cover (brand new)
      PC pipe works pipe
      Acerbis 100% carbon silencer
      Emig Racing top triple clamp
      Gold DID chain (brand new)
      Tag oversized bars
      Aluminum skid plate, disc guard, caliper guard etc
      Eline carbon fiber pipe guard
      Upgraded radiators (brand new)
      295cc kit has 12 hours on it
      Throttle cable (brand new)
      Steahly flywheel weight
      Plus much more.....
      Bike was just completely rebuilt, fresh grease, new bearings, new fork seals & wipers, new fork fluid, rear shock just serviced too. Ready to ride, needs ABSOLUTELY nothing and performs amazing.
      Bill of sale, have recent receipts
      Cash only
