dzr 400 power lack of problem
hi all im new on here,,,,i just bought a dzr 04 400 endurance,,heard alot about them so thought id give them a go,,im new to thumpers as ive always had race bikes,,,any way,,jumped on it and went to do a few wheelis,,problem was it never came up off the power,,had to give it marour clutch,,or majour tug on the bars,,all i get is 85mph no more,,someone said it might have bin geared up,,but this would obviously make it easier to come up off the power,,tried new filter but just the same,,,,any help would be much obliged,,,cheers folks,,,topp
Probably just gunna take some getting used to. the drz isn't really a "race bike" like you have been used to. What size sprockets does it have? Is it the supermoto or the S? Any upgrades or is it stock? How many miles? The drz is known for it's bullet proof quality and low maintanance, not power. Plenty of folks on this forum mod out their drz transforming the bike into a very agile/nimble wheelie machine! Check out epicmotosports and their 50hp package :thumbsup:
On the cheap, go with 14/47 sprockets if your not using your bike for much highway/commuting, and you'll feel more power.
A real E model with stock gearing would easily lift the front wheel in the lower gears.....either it is geared too tall or it's got some tuning and or some engine maintenance issues..
More details about the bike would be required to give an educated internet opinion..how many miles on the engine?, when were valve clearance checked,? what is the current jetting,? when was it serviced last?.Any other mods?..etc........ATM the best you could aim for is a SWAG.....
thanks for the replys folks,,totaly stock with stock gearing,,no mods that im aware of,,12000mls and dont know when the last time the valves was done,,,
and its the e model
and its the e model
Depending on it's previously use , it could be due for a top end rebuild or at least an inspection...
Give it a leak down test
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
