Sprocket Gearing
Right now i'm running ironman 12 tooth front, 51 tooth rear sprockets on my 08 450. I love the torque and pull of my bike but I kind of want a little bit more bottom end top speed. Since I need to replace my rear sprocket, what should I bring my teeth down to to bump up my speed a little bit... 50 or 49?? I do not want to sacrifice all of my torque though so i was kind of thinking just a 50 would satisfy me
13/51 should be just fine.. I run in for tight single track trails and it will still do 80ish
If you need to replace your rear sprocket?? You should be replacing the front sprocket and chain as a set..
  • Like 2
My rear sprocket is 2-3 years old and my front sprocket and chain was just replaced before the end of last season so trust me guys i'm not that much of a noob and like I said i do not need to replace the front sprocket only the rear.
I figured somebody would be able to offer some somewhat valuable input and experience but nobody wants to contribute to the subject so i'll wing it and order a 50 rear I guess.
Hey I am running a 48 tooth rear sprocket on my 06 CRF 450R and am wanting to go to a bigger size. I am thinking between 50-52 but can't decide! How has the 50 tooth one worked out for you? I ride mainly single track so I'm looking for some more torque.
I mostly race MX and some SX and on my '06 I experimented with a stock 48 and thried a 50 then settled on a 49. When I got an '09 I just went right to a 49. For you a jump from a 48 to a 52 would be big. I think a 50 would get you what you need. A little more torque without sacrificing much top end. You may have to add a link to go 52
Well seems like you know gearing etiquette so ill skip going up and down in front and rear yields yay result. Here is what I can offer, one tooth jump front sprocket you will greatly notice the change, one tooth jump on rear sprocket you will hardly notice the change. Also post chain length (ex. 116 for my 13/52 setup) next time so people can give you better guesses on wether or not you are going to need chain length work. Yes its a good idea to replace entire chainset when working on these parts but if you are confident you can match things up well I support ya. Just get a case saver.
I might have this wrong, so please take that into consideration, but I'm pretty sure I'm running 14/49 on mine right now -- I think I have the numbers wrong to be honest. I'll check tonight. Basically, I have the same ratio as stock, but with the bigger front sprocket the chain doesn't ride/dig into the chain guide as much.
ben
Sweet chart... would dropping my rear sprocket down to 49 teeth be that much more noticeable over 50 teeth or is it a minimal difference?
I had 13/48 on my 06 and I went to a 13/51. It has the perfect amount of bottom and top end power for tight single tracks. This is all opinion tho so if I were you I would try a 50 and see how you like it.
couldnt agree more!! just put on my new 51 tooth rear sprocket and have my stock 13 tooth front sprocket on my 06 and its a PERFECT combo!
Hmm... maybe i'll order a new 13 tooth front sprocket as well as my rear sprocket and try that combo out
I have 13/50 gearing and think its perfect. It had 14/50 when i bought it and i kept stalling in tight trails.now its perfect. I do 50/50 mx and trails
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
