dzr 400,,seems very sluggish
hi all im new on here,,,,i just bought a dzr 04 400 endurance,,heard alot about them so thought id give them a go,,im new to thumpers as ive always had race bikes,,,any way,,jumped on it and went to do a few wheelis,,problem was it never came up off the power,,had to give it majour clutch,,or majour tug on the bars,,all i get is 85mph no more,,someone said it might have bin geared up,,but this would obviously make it easier to come up off the power,,tried new filter but just the same,,,,any help would be much obliged,,,cheers folks,,,topp
is the bike stock?
has the 3x3 mod been done, jet kit?
how much do you weigh?
85 does not sound bad, but it should be able to get in the 90's imo.
When you say you're new to thumpers and have always had race bikes are you talking about 2 strokes? There is a difference in technique to wheelie a high strung (lighter) 2t than a modestly tuned (heavier) 4t. Start rolling the power on lower in the rpm range than you normally would with a 2t and use the torque to pull the wheel up. High horsepower DRZ's wheelie more like a 2t. Have you checked the accelerator pump to make sure the squirt duration is correct and aimed in the right direction? What is your current gearing? On my mostly stock motor I will typically clutch it up to wheelie when faced with an obstacle that's close (tight trail riding). The DRZ can wheelie like a champ but it's a lot about your technique.
have you tried the KTM mod?
thanks for the replys folks,,the bike is totally stock with the standard gearing,,superbikes as in road bikes 1000cc,,the 3x3 mod has not been done,,,,everyone ive talked to recons it should come up in 1st and 2nd no problem just off the power,,,,i know ive got it in 2 threads,,my mistake
Have a look at the jetting....remove the snorkel, it should just pull out....
With snorkel removed ..at near sea level..
160 main jet..... (not stock)
200 main air jet (stock)
60 pilot air jet ..(stock)
OCEMN needle clip 3 or or JD Blue needle clip 4 or stock OBDXP needle clip 5 (in order of preference)
45 pilot jet..(stock)
2.25 turns fuel screw
Optional ,but recommended......Remove the coast enrichener
Join the ports on the carb with a left over piece of hose and cap the port on the head..http://www.thumperta...29#entry9885029
craigo that stuff is wey over my head..lol
You're coming from liter bikes and you're surprised that a heavy underpowered dual sport is sluggish? Doesn't sound like anything is wrong with your DRZ, They simply aren't fast bikes.
Edited by SquadraCorse
it just that a few guys i spoke to sayd they come up no probs in 1st and 2nd off the throttle,and mine does far from that mate,,was just concerned that somthing wrong with it
If you have the S variant of the DRZ with the vacuum carb it'll be hard to lift the front end, cause it's a vacuum carb. You'd notice a big diference with the pumper card for immediate throtttle response. The vacuum carb slowly builds power.
BS! Really, so doing 95+ mph on a dual sport is considered ''not fast''
Good day sir!
Good day sir!
I believe he meant "not fast" as in holy sh*t this bike is accelerating fast and can roll-on wheelie in almost any gear... which I agree with, but it's all relative.
Hes also saying its heavy and ''underpowered'' i disagree, mine has the stock carb and lifts up the wheel effortlessly, no clutch or leaning back needed.
IMO tis a fast bike considering its a 400cc dual sport bike.
And yeah, its a bit heavy :D
Go through the FAQ section. And try searching fcr jetting. Read up and you'll understand.
Mine wheelies just fine 1st and 2nd.
Sounds like technique or problems with Your bike.
Take some of the good advice given here.
Check jetting.
3x3 mod
Remove coast enricher
Eddie mod
Exhaust stock??
Any other symptoms?
strange noises?
coughing, farting?? :laugh:
thanks so much for all the replys,,it has stock exhaust,,how will i know if its the vacume carb?? on the books it states its the sk4 model..
,,,whare will i get the pumper carb as mentioned mate
best start would be to take a pic of your carb and post it up. Like others have said it will take some technique for you to get a stock DRZ up, although the E version should be better than the neutered S model we get in the states.
For a second gear power wheelie I pretty much have to give it a little bounce. Now if I clutch it, it will come right up so long as I am low in the RPM range. When I say low in the RPM range I'm talking 20-22 MPH in second gear with factory 15:44 gearing and deathwings.
It should power wheelie in first no problem through an intersection.
right had a look on forums and google,,sounds like i have the vacum carb,,whats the best thing to do the,,change carbs,,and what kind and what will be required,,or is there mod i can do to the vacuum carb?
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
