Spark Plug Problems
I have a 2005 KX125 thats been fouling plugs, i've been using NGK BR9ES plugs and this is how it goes: I put a brand new plug in it, starts on first kick, I let it warm up and it runs perfectly. I can cut the bike off and let it sit and crank it back up first kick no problem. Then, I put it up for the night, and the next day when I go to ride it'll start up first kick, run and idle and all, and then bogs down after about 2 minutes and fouls the plug. I can try to clean it but nothing works so i throw a new plug in and the same process repeats.. Anybody have any ideas on why it does this and how to fix it? PLEASE HELP!
Also sometimes on the day after I notice just a tad more smoke than the day before...
Has this problem suddenly come up? Did you buy it like this? Are you loosing tranny fluid? Whats the jetting? How does it ride? Info Info Info....
its the mans first post ! give him a break ! start by posting a picture of your plug. what is your fuel/oil mixture? do you have alot of black oily stuff coming out of the exhaust or where it ataches to the exhaust?
Didn't mean to sound harsh, but nonetheless the more info the better. Pics are great too.
Don't know what plug should be in that bike, but a 9 is kinda cold.
I think 9 is pretty common for 125's
When I bought the bike it had a different plug.. didn't pay attention to what it was but the guys at my local shop said the NGK's i'm running should be fine. I always mix 32:1 with high performance mix and premium no-ethanol gas. Yes there is black oily stuff that collects at the end of the silencer.. but i have a shorty and heard that that was common. Also when I pull the plug after it fouls its always black and wet, not dry and dusty.
How does the air filter look?
Clean, I washed it 2 weeks ago
By the way, the stock plug is the NGK R6918B-9, so a "9" is the correct stock heat range.
Is the bike ridden on a MX track, trail ridden or what?
What is your pilot jet number?
Not sure on the jet numbers.. It has an aftermarket Mikuni carb on it and I mostly trail ride, but I stay on the pipe a good bit and I'm not under powering it.
It does not have the stock Mikuni carnuretor?
Oh I guess it does..
If you can answer my questions that would help tremendously.
Sorry, and no I didn't buy it like this it was fine when I bought it but I fouled the original by not letting it warm up. I've only had it for about a month so yes it suddenly came up, no I'm not leaking tranny fluid, I don't know the jetting but the stock Mikuni carb is on it still, and it rides fine, runs, idles, jumps, and stops, like it should.. No throttle studdering or anything
It is jetting be best to get a Kawasaki repair manual around $35 dig into that carb and find out what jets are in it. Disassemble clean and re-jet "leaner" and replace that packing in the silencer also. I'd also run a compression test to make sure the motor is ok, low compression can make it go fat.
Edited by JBFL
Thanks! Ill get a manual and see what I can do
Team Green suggests going one leaner on the pilot and main.
Are you familiar with the air screw?
I believe so.. It's the screw on the left side of the carb with a Philips head right?
  • Similar Content
    • By 2strokesnpowerstrokes
      Hi y’all so I have a 2000 kx 250 that I bought about two weeks ago. Everything is good on the bike except I bought it without a kickstarter lever so I have to bump start it to start the bike. Runs good when bump started. Anyways I have ordered two kick starter levers now and they both have not fit. The first one was off a 1996 kx250, the second was off a 2000 kx250. Both of them do not fit, they are to small to slip onto the kick starter shaft. I’m confused to what is going on and why neither have fit especially the one for a 2000 kx250. My vin, air box, and cylinder numbers state that the bike is a 2000 kx250. However I cannot figure out what year my motor is, every forum I’ve looked up skips my engine number. Please help y’all
      Engine number: KX250LE022273
      Vin number: JKAKXMLC4YA017773
      Air box number: 1743
      Cylinder number: 1911
    • By DirtBikeHead
      1996 KX250 beautifully restored....
    • By Shawn658
      I am trying to find out if the water pumps for the KX250'S will interchange. Seems most parts from 96- 07 will. Can anybody help me out? My plan, put a Boyesen Supercooler for a "05" model on to my 99. Will this work? Any help is appreciated! Thanks
    • By Daniel Wolfe
      So i know my way around a crab pretty well and i'm very familiar with them i just can't seem to get the kawi dialed in it seems to have this unging/erratic rev thing going on when i pull in the clutch and i slow down so i'm looking for the correct carb adjustment for the bike it didn't seem to do it when it was warm out but now that it's in the 30's forties it's doing it my elevation here in upstate ny is 295' it's been around upper 30's lower 40's but i'd like to tune it so it's ready for summer because i don't ride it much in the cold so i'd like to tune it so it would be best in 70-90 degree weather since that's pretty common around here So could someone please help me out I need to know what the fuel to air mixture is needle position and proper jetting thank you
    • By Henry Nichols
      Okay guys, I have a 1997 kx250 frame and I wanna know(if even possible) if there are any 2 stroke engines besides the original that will Bolt onto the frame without any modifications.
