stiff rear tire?
went to tighten chain today, noticed rear tire was a little stiff, as in doesnt spin freely, anyone had trouble with their rer brake sticking?
Was that with the chain still on? Or did you take the chain off and spin?
chain on, but wasnt to tight.
Hum... Well easy to figure it out. Try taking chain off then spin. If its still stiff maybe try spreading brake pads a lil bit. Last and only thing is wheel bearings.
Or countershaft bushing. DAMHIK
How do you know? Haha :D
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
