Connecting rod
Is there suppose to be any kind of play in the connecting rod where it connects to the crank
There should be some side-to-side play, but zero up-and-down. Sometimes it's hard to make a distinction between the two. Is this machine something that was running before you pulled the top end off? Was it making bad noises from the bottom end?
I bought a used bottom end off of eBay because the one that was originally on it threw the rod and destroyed the whole bottom half I the engine the guy I bought the motor from said it came off a good running bike
