97 KX 250 shock compression setting...
So I've searched but can't seem to find an answer for this... On my shock, the compression screw is the one on top right? When I turn it all the way in it doesn't seem to make a difference.
When I turn the rebound screw all the way in it actually locks out the shock after a compression stroke.
Should the compression screw have a similar effect? I was hoping I could stiffen the compression a little more because I'm a bigger rider.
compressions on the bottom dudebroman
Compression adjuster won't lock it up.
What do you weigh in full gear?
Do you have the stock spring on it?
Any bike, any rider, it HAS to have the correct spring rate to work best.
EDIT: On the shock, which is on the rear of the bike, the compression adjuster is on the top.
Edited by KDXGarage
No... should you go back and check your settings now?
But it is normal for the rebound screw to lock it up to a point?
When I have rebuilt a shock in the past, I will compress it totally by hand, hold it fully compressed, then turn the rebound adjuster all the way in. It would lock in place. This is without the spring in place.
on the shock, compression is on the top. on your forks, compressions on the bottom.
Considering that its a 97, you prob need the shock serviced. if the adjusters doesnt seem like its doing much anymore, you could have lost nitrogen over the years, lost oil, broken down/dirty oil etc.
also, adjusting your compression will not be effective if you're too heavy for your springs
check out racetech.com for the correct spring rates for your weight and riding ability
Edited by jkenney177
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
