Ktm 50 sx lc coolant comin from every where?
I just picked up a 04 sx pro 50 for my son. The water pump was leaking so I replaced it all including the ignition cover. Now it leaks around the pump wheel cover, the hoses, the head the jug. It's comin from every where. Instantly. Not even when it's hot.
I jus put a new clutch new mtl oil new liquid performance coolant. I'm so disgusted. Any help???
Probably head gasket/o-rings. Don't know which one it uses. Pressure from cylinder getting into water jackets pushing fluid out. That's my best guess.
I ordered a full engine gasket set and I'm having my extra water pump assembly pressed in to my extra ignition cover. These little bikes are a bear.
